Question about Apogee One - Usb Audio Interface W/ Internal Mic,
Apogee one internal mic - hiss
When recording with the apogee one internal mic I get a huge amount of hiss and can't figure out how to get rid of it.
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
Laptop internal microphone stopped working
your need go to device manager on the internal mic thing click on it and rollback driver to original or update it one of those should work or go to control panel under sounds then recording devices and clic to make you internal mic your default mic and make sure its not muted
Nov 12, 2012 | Medion Computers & Internet
I got a rode classic II with avalon m5 mic pre. So when i crank up my mic pre to 60 n i can start listening some hissing from my monitor...or is it normal for a valve mic coz when after recorded with this...
The hiss is caused by your monitor system level and your preamp gain being so high. At high gain settings, a preamp is going to get noisy, and tube mics have a higher noise level to begin with.
If you can't hear it on your recordings, then it's not a problem.
Sep 17, 2011 | Rode Classic II Professional Microphone
I am getting a lot of hiss when I record low
it is not a problem there are many problem
Aug 23, 2009 | PreSonus Computers & Internet
Mic stop working
Open Sound devices from Control panel & do the following
1. Click Advanced button in Volume tab
2. Select Properties from Options menu
3. Click Recording & press ok
4. Now select Internal MIC
Hope this solves your problem
Aug 03, 2009 | HP Pavilion dv7 Keyboard (483275-001)
Hissing sound when recording
hissing sound when recording is due to old microphones or frequency interuptions if you have a wireless mic i suggest you to find a new mic, or if you have singstar use their mics
if it is video recording then buy a new camcorder
Jul 07, 2009 | Electronics - Others
Engines for the estes astrovision rocket
It's safe enough, but you better have a huge recovery area.
Apr 12, 2009 | Estes Rocket
A buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Jul 18, 2008 | Electro-Harmonix EH-TM Microphone
IBM COMPUTER -- SOUND BLASTER SOUND CARD PROBLEMS
I presume you are going in through the mic socket on the audigy?
If so the most likely cause is a mismatch between the mic and the mic amplifier on the card, they are designed for cheapo condenser mikes that have a fairly high output.
Also make sure you disable any inputs that ar'nt in use to minimize noise.
If you have the Mike plugged into the line in you have it in the wrong socket.
The best way to get a good result is use an external mic amp or mixer and go in through the line in. Again make sure you disable any inputs your not using (in the computer mixer) and turn down any sliders on the external mixer that ar'nt in use to minimize noise.
If you'r still having problems get back to me with a more detailed description of your setup, whats plugged into where etc...
Best of luck
Jun 07, 2008 | IBM Creative Sound Blaster Audigy Sound...
Hissing from one of the two NT5 mikes
have you concluded that it is 1 of the mics?if mics are ok you need to purchase a mic pre.
May 28, 2007 | Rode NT5 Professional Microphone
Apogee One - Usb Audio Interface W/ Internal Mic, Logo
61 people viewed this question
Top Apogee Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Apogee Audio Player and Recorder Expert? Answer questions, earn points and help others
