Question about Pioneer VSX-818V-K Receiver
Pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
I Have a PS3, AT&T U-verse HDDVR and a VIZIO 47" TV all connected and working just fine with HDMI. I added a pioneer VSX-818V-k and I have no video or Audio. When I set the reciever to TV it says the TV cannot support HDCP ERR(H1001) and when I go to to DVD/BD on the reciever for the PS3 I have a black screen. Please help.
  • 1 more comment
  • Anonymous Jan 12, 2009
    I have the same Problem. I have a Sony TV, the PS3 works fine with the HDMI input. However, if I take the HDMI input to the Pioneer VSX-818V and the HDMI output tot he TV I get a black screen. My solution was to take the HDMI from the PS3 direct to the TV, and then use the Optical digital output from the PS3 to the Pioneer optical digital input. Not really ideal solution, but it works.
  • jrlarsen Jan 12, 2009
    So, Is it best to just run all HDMI and component cables to the TV and a Optical Digital Output from the TV to the receiver?
  • Anonymous Jan 31, 2009
    hooked up to directly to the tv, it's fine. when passed through the pioneer receiver, i get this error. booo.
That model does not support audio via hdmi. That is the problem.
Posted on Feb 07, 2010
  • akovacs62 Apr 03, 2011
    Sorry,but this is exactly what we found out on our own.
    You didn't help at all.
    Thanks
    Andrew
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
I just hooked up our Vizio E420VL 42" LCD HDTV.
well if you have cord going to ur u-verse then check your rca jacks red and white and see what inputs they are in and another thing hopefully your sound card has not gone out but let me know what happen
Dec 06, 2010 | Vizio SV422XVT 42 in. LCD HDTV
Connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
Jun 10, 2010 | Pioneer VSX-818V-K Receiver
Just got att u-verse and the digital audio output is distorted.
I'd run this by ATT.
If the audio output digital feed is strong enough for the receiver to accept it then the actual audio on the digital carrier is probably the problem. If there is a coaxial output on the cable box, I'd try that, too, to isolate the optical and HDMI as the problem or not.
Or shoot the cable audio into the place your Blu-Ray is connected to prove if it works the same or different.
Apr 26, 2010 | Pioneer VSX-1019AHK A/V receiver
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
No Sound from Subwoofer
The original Pioneer subwoofer has its own amplifier built in to the speaker, so the only cable required on the original speaker is a single RCA cable. To connect a different brand subwoofer to the Pioneer you will have to make sure that you have a subwoofer with the same specs. It will need its own built in amp to work, as you can only connect it with one RCA
Jul 31, 2009 | Pioneer VSX-818V-K Receiver
When I turn my 32" vizio on I get no signal sign. I have my tv connected with 12 ft HDMI to U-Verse Mot cable box. My cable is in the wall and very difficult to replace.
It could be that you have it set to the wrong input. Use the input button on your remote control to go through all the different inputs, unti you find the right one.
Jul 16, 2009 | Vizio VO47L 47 in. LCD TV
U-verse remote code for a Vizio HDTV
1343 is the closest one I've found that works, it will turn the TV off and on, control the volume, and enables mute. The only other thing it doesn't do is change the video input, I'm still working on finding that. If this helps, please give me some kudos.
Nov 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Pioneer VSX-818V-K Receiver Logo
1,369 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
