Question about NEC Univerge Dtl-12d-1 680002 Dt300 Refurb Warranty
Dt300 display message
Cant figure out how to turn off selectable display message
MY NEC DT300 DTL-24D-1P IS SUDDENLY CHANGING THE LANGUAGE DISPLAY FROM ENGLISH TO JAPAN
Try to find someone who understand japanese language to reset that. If you dont find anyone?. The easiest way is to reformat your unit.
Sep 29, 2016 | NEC Computers & Internet
Dt300 digital lamp timer
Copy following lin
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
Press reset button and reprogram
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 04, 2013 | Hardware & Accessories
Intermatic digital lamp timer dt300. I can only get to set it to 24 hour. it does not go to 12 hour when i reset and then hold down the clock button. what am i doing wrong?
There is no repair for defective timer.
The DT300 is sold under at least 3 different brands and product numbers, and each manual shows identical steps for choosing 12H and 24H format.
The manual says to press and hold CLOCK button until display shows 24H. Then press HOUR button to change to 12 hour format.
I am guessing this step cannot be done if timer has programming in memory, so timer has to be reset first by pushing in reset button for a few moments.
Open following links to identify timer and download manual:
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Intermatic Hardware & Accessories
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
I'm trying to change my picture on my Yahoo Messenger beta
go to messenger, then scroll to my displayed image, then click on my share image and then click on select, and click on browse to bring up ur pics in your my document or my picture, then select and click ok
Aug 08, 2009 | Yahoo Messenger
Cant figure out how to set the time
1> Press and hold the select button. The setup display appears. 2> Press the select button repeatedly until "CLOCK-ADJ" appears. 3> Press (DSPL). The hour indication flashes. 4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL). 5> Press the select button. The setup is complete and the clock starts. To display the clock, press (DSPL). Press (DSPL) again to return to previous display. The clock uses a 12-hour digital indication.
Jun 15, 2009 | Sony CDX-GT300 CD Player
Having problem with focus, cant even read the menu sharp dt300
try cleaning the color wheel with rubbing alchol and a q-tip
Feb 21, 2009 | Sharp DT-300 Multimedia Projector
NEC Univerge Dtl-12d-1 680002 Dt300 Refurb Warranty Logo
21 people viewed this question
Top NEC Audio Players & Recorders Experts
richie46
Trippy Tripp
Najib Cambris
Najib Cambris
Level 1 Expert
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
