Before I open anything by short cut icons, I would also like to have a short cut icon for Open Office 3.4
SOURCE: pls help my toshiba pc cannot open the main screen
im from philippines..im 17 years old,my name is romano p. labandelo jr.im 2nd year college graduating of computer technology....its easy reinstall your o.s and click the repair....thats all..contac me in my yahoo [email protected]....
SOURCE: boot-up takes more than 7-10
yoy can try to scan and fix the Resistry it could help but its more deep its better to delete the partition and install it could be that the VOL/SYS is corrupted and its taking long to recover.
SOURCE: Double click left mouse button on desk top icon
Sounds like your registry might be a little "Off". Please download this program
http://download.cnet.com/CCleaner/3000-2086_4-11042369.html
Run it and restart your computer.
Also, go to your Control Panel, select Mouse, and choose to have the mouse operate on the left.
Blssed be
regards
selk
SOURCE: I can't open the icons the desktop screen.When
Most likely the problem is that the association for .exe programs has been lost or changed, Commonly caused by malware/etc that tells you everything you have has a virus in it (super annoying)
Opey My Documents or My Computer, Select Tools '
Folder Options then the File Types Tab. Scroll down to where .EXE would be in the
alphabetical order and make certain .EXE is not there (if it is, then edit
it there by changing the association to Application). Finally, select the New
button, type in EXE for the extension and select the Advanced button. From
the list pick "Application." It
should look something like this.
While not shown on the picture above there should be a "Restore" button you
can click. If so, use that and, hopefully, this should cure the problem (thanks
to forum member diginono for finding and posting this solution). The Restore
button only shows up when there is a problem on the system.
If this works but there is still a problem with LNK files
then scroll down to the end of this FAQ for a solution to that.
If that doesn't work, Here is the full page on it.
http://filext.com/faq/broken_exe_association.php
