Question about Blanco Plumbing
Want to buy a blanko sink strainer plug - Blanco Plumbing
  • 11 Answers
SOURCE: peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Posted on Jun 06, 2009
  • 760 Answers
SOURCE: Use foam gasket on sink strainer along with plumber's putty?
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Posted on Jul 06, 2010
packrat1948
  • 528 Answers
SOURCE: I have a White Blanco sink strainer that needs a
This link is showing meny places to buy the strainers.
http://www.bing.com/search?q=Blanco+sink+strainer&FORM=MSNTBG&PC=MSNTDF&MKT=en-us
Posted on Feb 10, 2011
  • 1015 Answers
SOURCE: What strainer/disposal basket do I need to buy for
I believe this uses a standard 3 1/2 inch diameter basket strainer.That is also the right size for the disposal. Thank you
Posted on Feb 26, 2011
SOURCE: I installed a black granite
This is all wrong! You can't use plumbers putty on a granite sink! You're supposed to use a sink and tub caulk which unfortunately is a real pain to get seal. Read the directions on a granite sink... they say DO NOT USE PLUMBERS PUTTY!
Posted on May 12, 2012
I am installing a Blanco cafe brown sink basket strainer. The directions state that a thin bead of silicone, not plumber putty, goes at the bottom of the sink hole. Is this accurate?
Yes The Blanko is installed with silicon not plumber putty. This is common with the newer sink strainers
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 15, 2011 | Blanco Sink Waste Strainer / Stopper...
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
What strainer/disposal basket do I need to buy for Porcher Farm Sink? Sink did not come with strainer/disposer trim.
Feb 26, 2011 | Porcher 35020 London 30" Single Bowl Farm...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
I need to find replacement white rubber feet for my Kohler sink basin rack,
Call Kohler Plumbing customer service: 1.800.456.4537, choose option 2 for service parts.
Tell them you need a "Feet Replacement Kit" for whatever model name/number and color your basement rack is. Prices run about $1 per piece plus shipping.
Feb 12, 2011 | Kohler K-8803-VS Duostrainer sink basket...
Rubber feet on stainless steel sink basket are falling apart
Kohler is generally good about standing behind their products. I would get a hold of customer support and they should help you with that.
Nov 27, 2010 | Kohler K-8803-VS Duostrainer sink basket...
Peeling paint coming off of oil rubbed bronze basket strainer
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
Plumbing Logo
74 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
