Question about Electrical Supplies
I have a generac 15,000 watt generator. Gp15000e. At first right before the storm, it wasn't getting spark intermittently and sometimes it would start. Long story short, a guy came out and changed the circuit board inside and it had spark but still didn't run. The owner of the company came and disconnected fuel switch and now it runs. But now there is no AC output and there was before the board was changed and it runs at wide open throttle when choke is in. I have no idea what's wrong and the guy won't come out for a few days.
SOURCE: generator runs for a short time
does your generator have a metel tank? If it does it probley has rust in the shut off valve under the tank.
Posted on Nov 30, 2008
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Posted on Dec 16, 2008
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
Cant get it to turn over
charge battery,fill oil,turn switch to on,try to jump the solenoid,if it turns over,it is the solenoid
Jun 13, 2015 | Generac Guardian Ultra Source 15,000 Watt...
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
The current starter battery is not recharging. I would like to know if there is a problem with the alternator or battery charging mechanism. If so, is there a replacement part available ??
Hi Frank,
Have you charged the battery and see if it holds a charge? If it does, then it's probably your alternator.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 27, 2011 | Generac Guardian Ultra Source 15,000 Watt...
I have a Generac XL4000. It rill start but not run right.
If the area you live in has alcohol added to their unleaded gas, then you will probably need to rekit the carbuerator. Also check the spark arrestor for plugging up. Try to find a non alcohol, off road unleaded gas for your generator.
Jan 20, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
I have a Generac 15000 watt portable generator. It cranks great, but will not start. The plugs are wet, doesn't seem to be getting any spark. Have replaced plugs, any suggestion.
I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
Apr 05, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Electrical Supplies Logo
141 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
