Question about Baumatic Washing Machines
Baumatic bk6el washing machine instruction book
Lights flashing full of water
4 Suggested Answers
supertech6
  • 513 Answers
SOURCE: We don't have an instruction manual for our
This has a strong indication that the machine needs a controller. A controller can be from $80 - $400 depending on model and type. Good news is they are generally easy to change. I recommend a new knob with the controller as you will likely break it getting it off without knowledge and special tools.
Check this website for parts:
http://www.prontoparts.com.au/
Posted on Mar 22, 2010
rickead1
  • 1998 Answers
SOURCE: Baumatic BK6EL washing machine will
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Posted on Aug 11, 2010
quintsmartas
  • 10 Answers
SOURCE: hi i have a baumatic bk6el/6kg washing machine at will not spin out on its final spin.
May be your timer, go to Britishjames.com
Posted on Oct 27, 2012
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Apr 06, 2013 | Coffee Makers & Espresso Machines
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
"Add Water" light keeps flashing even when full.
Reserve is not in position and needs to reset. Pull and try again.
Feb 26, 2012 | Keurig Platinum B70 Coffee Maker
Unit wont turn on,,, water full light flashing
is it full of water if not maney times it senses a full tank by a scale on the bottom of the water pan try to pull up on the plate where the bucket sits make shure its not stuck let me know pls jason
Apr 08, 2010 | Maytag M7DH45B2A Dehumidifier
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
The "tank full" light flashing
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Jun 08, 2008 | Toyotomi TID-2400 Air Conditioner
Washing Machines Logo
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
noel
noel
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
