Robus rrf10 central heating room thermostat wiring instructions to boiler needed
Connections to 9.24 heatslave boiler?
4 Suggested Answers
  • 36 Answers
SOURCE: wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
Posted on Jan 24, 2010
  • 36 Answers
SOURCE: fitting room stat
take the link out and fit stat wires in its place,will work then.
Posted on Jan 31, 2010
  • 2463 Answers
SOURCE: I have recently been installed with new central
0 t0 5 is the range just set the to what number gives the temp you like in that room thats it
Posted on Nov 27, 2010
How to set boiler timer
Find typical timer modules and manuals following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#PB
Gene
h
Jan 17, 2014 | Hardware & Accessories
I do not have a room thermostat connected to my oil fired central heating boiler. I want to install a wireless room thermostat to avoid having to run cable. how do i go about this and which is the best...
All wireless wall thermostats are Millivolt controlled. rather than having an 18 or 24 volt (transformer) wired wall thermostat. Before purchasing any wireless wall thermostat, you need to determine what your oil fired boiler requires for activation. My experience tells me, that it's going to require either 18 or 24 volts. In which case a wireless thermostat won't work.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Hi, I have just replace the room thermostat on my oil fired central heating system it is an RS1, which requires only 2 connections plus an earth. I had to get this one as the flex from the stat to the...
Well in your case,if the central heating was working before you change the defective thermoatat.Phaps you have done the wrong connection of the thermostat,if you look well at the connection of the thermostat, how will you recognise the earth borne is that it is fixed to the body of the part,so this means that the thermostat 3 cores are (1) common,(2) normally close,(3) normally open.With a multimeter it be very easy to determine the core that you have to cannect.
Oct 04, 2009 | Plumbing
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Wiring of gas central heating
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
Heating & Cooling Logo
679 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
