Question about Kohler K 304 Rite Temp Pressure Balancing Valve
No hot water all of a sudden
I have a Kohler K-304-KS valve body with screwdriver stops. All of a sudden only cold water comes into the system. I took apart the unit till I only saw the back of it where the water from the brass part comes in. When I turn the hot water stop back on only a trickle comes in. When I turn the cold water stop back on, a jet of cold water comes out (as it should). How do I get the hot water to flow past the stop valve??
  • Lonzy Nov 02, 2012
    ITs not the pressure balance unit. i turned off both stop valves and removed everything up to the main brass valve assembly. then when i turn on the hot stop valve only a trickle comes in. when i turn the cold stop valve on I get a solid jet of water. something is wrong with the hot water stop valve?? I live in an apt bld and shutting off the main water feed is not a simple thing.
Cold water going through to hot side
Replace pressure balancing spindle part number 500520 from Kohler, if you purchased part Kohler warranty may cover issue, Kohler Customer Service 800-456-4537
Apr 09, 2014 | Kohler K-2971-KS-NA Hiflow Rite-Temp Valve...
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    My hot water suddenly stopped flowing. I have a good water supply, the cold is fine. The water heater is full and is hot, but, no water comes from any tap. PLEASE HELP !!!!! Dennis K.
    I had the same problem and I took out the two shut off/by-pass valves (unscrewed handle and removed cartrige) to find that lime build-up had virtually sealed the lines so that no water flowed!
    Cleaned out the lime deposits and reassembled valves and water flowed once again.
    Sep 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
    Very little cold water, lots of hot from kohler shower valve
    Probably some pipe rust clogged the exit.
    If u have pretty low presure as default on both hot and col water, try keep force closed by hand the water exit at shower pipe, then start both cold and warm water gradually as much as u can keep it closed with the hand.
    The hot water pressure going back thru the cold water pipe might unclog that debris.
    Just a simple fix which many times works as a charm..
    Otherwise if this is not fixing, try close both water from main service valve.
    Then unscreew the secondary shower valves and manually clean them or replace if very damaged.
    Dec 14, 2017 | Kohler K-T10335-4-CP Lyntier Rite-temp...
    Kohler shower valve (hot/cold switched)
    Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
    Dec 19, 2009 | Kohler Forte entertainment remote valve...
    When I turn the cold water faucet off water still runs out unless I back it off a quarter of a turn. It is the cold water valve for my tub. It is less than 5 years old. I can remove the decorative bell...
    I dont know the modle fauset you have ,but it sounds like your cartridge has turned in the valve body. It should lock into place in the valve body with a tang in the cartridge and a slot or groove in the fauset body. If the whole cartridge assembly turns in the fauset it will couse this problem.
    Dec 14, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
    The hot water stops coming out of faucet
    if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
    Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
    No water coming out of my Kohler Forte R10275-4-BN shower valve
    This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
    Good Luck, Phil
    Dec 25, 2008 | Plumbing
    Kohler K 304 Rite Temp Pressure Balancing Valve Logo
    141 people viewed this question
    Top Kohler Welding Tools Experts
    Bill Boyd
    Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
