Question about HP LaserJet 2200D Printer
Does not printer lowercase letter "f"
I have an HP 2200d laser printer that does not print the lowercase letter "f" in MS word and Notepad. All the other letters print ok. I have downloaded the latest driver from the hp website. Does anyone have any ideas why it's not printing lowercase "f". Is this a hardware or software problem? I've notice that only certain fonts are affected by this problem. Weird?
  • 4 more comments
  • Tung Trinh Jun 04, 2007
    Connected the printer to a different computer and still got the same problem.
  • Tung Trinh Jun 05, 2007
    Followed your instructions and found no cards installed, just found 2 empty slots on the formatter board. Where can I purchase these cards?
  • Tung Trinh Jun 09, 2007
    Found a 32mb HP LaserJet Memory card(C7845A) off ebay. Installed card into one of the slot and got 3 blinking LEDs, then reinstalled it in the other DIMM slot. Checked and rechecked to make sure that card was installed correctly, but still getting 3 blinking LEDs. The notches line up and the clips snap the card into place. It seems to be installed correctly but the printer does not like it. Don't know if it is a bad card or a bad formatter board. Will try to find a new DIMM card....(to be continued)
    Removed the DIMM card and turned on printer. Got the green LED (ready), then initiated a self-test:
    Product Name: HP LaserJet 2200
    Formatter Number: ???
    Product Serial #:CNDRC42010
    Service ID: 11289
    Firmware Datecode: 20010104
    Printer does not like the DIMM card and still does not print lowercase "f".
  • Tung Trinh Jun 15, 2007
    Finally, got a new DIMM card. Installed the card without any problems. This means that the previous card was defective.
  • Anonymous Mar 26, 2014
    random small letters lite in color
  • 40 Answers
Do you have another computer to connect this printer to in order to try and recreate this issue? It may help determine if the issue is the printer itself.
Posted on Jun 04, 2007
  • Chris Yost
    Chris Yost Jun 04, 2007
    While I'm researching this issue, here's something to try. Be sure you have enough room around the printer before starting. If you have an anti-static wrist strap, I recommend wearing it.
    If your printer has an optional font card, it may be the problem. If not, it may be corrected by simply reseating the ROM DIMM and any additional memory that may be installed.
    Turn your printer off, then unplug it.
    Facing the printer, you're going to remove the right-hand side cover. This is done by pressing the 2 plastic pins in the back, one on top and one below. This unlocks a little access door that swings forward.
    Open the toner door. You'll see a small plastic button that locks on the right side panel. Push it down and push the right side panel forward, it stops after about 1/2". Swing it forward and remove it. You've now uncovered the formatter board.
    Toward the front of the board you'll see one or more smaller cards that resemble small fat PC memory. One is the system ROM. Others may be additional memory and/or the font card (remember, you may not have one, this is just how we find out).
    Pop out each card ONE AT A TIME by pressing the little white clips on top and bottom. DO NOT TOUCH THE METAL CONTACTS!! HANDLE IT ONLY BY THE EDGE! Pull the card out and reseat it, the which locking clips will clip to it automatically when you reinstall it, and it only installs one way.
    Reinstall the side panels in reverse order. Plug in the printer and test.
    As complicated as all that may sound, it takes around 2 minutes. Meanwhile, I'm still researching. If all of this doesn't work, please tell me how many cards were installed, and the printer's serial number.
I m printing with HP Laser Jet 2200D and it is missing letter "U" all the time
Hi..............
Please do the following :-
  • On the Printer Properties /Device Settings tab , enable JPEG Passthrough
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Samsung HP 2200D LASER JET Printer
I am using Dell 3100cn Laser Printer and I can not print using MS word, but I can Print with Notepad...
Be sure when you print under MS word that you have the correct printer selected in the drop down menu. There will be a menu with a choice between something like "Microsoft Image Writer" and your actual printer, ensure the actual printer is selected.
Best, Mark
Mar 28, 2011 | Office Equipment & Supplies
HP LaserJet 2200D - margins cutting off on the left; not all docs
go to hp's website, they have an excellent site for trouble shooting.
Apr 29, 2010 | HP LaserJet 2200D Printer
HP2200D printer missing disc need to install
See if you can download the driver FREE from the HP website. Search for your model. If you are on Vista, it may NOT support the older printers.
If not, try driverguide.com. The latter you have to sign up for but it is free.
Oct 19, 2009 | HP LJ 2200D Laser Printer
Garbage printing
Hold both buttons while powering on the printer. Hold them both for a least 20 seconds and release. When trouble-shooting fails, sometimes the NVRAM can be the reason for the strange behaviors.
Mar 26, 2009 | Samsung HP 2200D LASER JET Printer
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Printer problem
    Try replacing your laser unit. They are known to make a high pitch sound when they go bad.
    Oct 29, 2008 | HP LaserJet 2200D Printer
    Does not print lowercase "f"
    This is definitely a software problem. Or pssibly a keyboard problem. Not as printer or driver issue.
    May 18, 2007 | HP LaserJet 2200D Printer
    HP LaserJet 2200D Printer Logo
    367 people viewed this question
    Clive
    Clive
