Question about Refrigerators
Kenmore elite bottom freezer stopped making ice,light doesn't come on and switch that allows light to come on gets frozen bought in 2008 new
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
  • 2336 Answers
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
  • 409 Answers
SOURCE: Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Posted on Oct 03, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
  • 103 Answers
SOURCE: Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Posted on Jun 07, 2009
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I opened freezer on my Kenmore elite model #596 73503203 and everything was melting, ice had started to turn to water. The refrigerator is only 7 years old, is it worth fixing? The freezer does not seem...
It could need refrigerant...I'd try to possibly get a quote on that.
BUT FIRST,
I'd ensure the coils were cleaned of all dust and dirt...either by vacuum or blow it with compressed air.
I'd also check to make sure the light goes out when the door is closed. Sounds crazy but I had a bad switch once that allowed the bulb to stay on constantly...makes everything warm.
Jul 17, 2011 | Kenmore 73503 Stainless Steel Bottom...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
The icemaker in the door of our Kenmore Elite Trio frig just stopped working, exactly 13 mos. after we bought it. We did not get an extended warrantee, because we have never had a new appliance fail so...
Is the ice unit turned on? I pushed the off button by mistake and PAID someone to "turn it back on for me" The guy laughed all the way to the bank :( Also he said a good place to start , before I call next time, is have you checked to see if there is a ice cube frozen(caught) in the top.Pull out the ice catcher(bin) and check for the frozen cube of ice. Be sure to turn off the ice maker first or it may drop ice when you least expect it! My fridge is the origional for house (18 yrs) and after I've done this check list, the problem is fixed. Just thought I mention it. Good luck!!!
Mar 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
hi there,
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
