Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Change code on powerbolt 2000 - Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
I need to change the code on the lock . I just purchased a House with this lock and no instructions were left to change the code. I know other people know this code so I would feel alot safer to be able to...
Here is a link to the installation and programming instructions for kwikset Powerbolt:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Here's the main product page:
http://www.kwikset.com/Products/Categories/Electronic-Locks.aspx
Feb 23, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Trying to program new code
Here is a link to the Frequently Asked Questions page for the Powerbolt 1000:
Changing the code is explained there. Good Luck!
Feb 02, 2011 | Weiser Lock Powerbolt 1000 Lock
We lost the directions how do you change the code and how to get the back off
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Dec 01, 2010 | Weiser Lock GED1460X3BR Lifetime Polished...
Changing the unlock code.
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Oct 06, 2010 | Weiser Lock GED1460X GED1460X3BR Lifetime...
Need to change combination
Jun 01, 2010 | Weiser Lock Powerbolt 1000 Lock
Changing the code
Apr 13, 2010 | Weiser Lock Powerbolt 1000 Lock
How to change batteries
The instructions for changing the batteries and reprogramming the code can be found there. Good luck!!
Mar 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
