Can't get my dell Inspiron 1525 to work. Tried all the obvious . It simply won't load anything. It freezes just when you think something is happening. Please help
  • max carson
    max carson Nov 01, 2012
    Here is another tip, if you haven't tried:When the Dell splash screen appears during startup, press + and release them at the same time
  • max carson
    Try to "Cold-Start"your laptop: 1) unplug from AC outlet, 2) remove battery,3) hold on/off button for 10 seconds, 4) replace battery 5) plug into AC outlet, 6) try to boot normaly. let me know what happens.If it fails repeat process and when you push the on/off button REPEATEDLY TAP THE F-8 KEY until you get a response. let me know what happens.
  • 7,627 Answers
Posted on Nov 01, 2012
mgdev24
  • 59 Answers
SOURCE: webcam not working
if your note book is new then **** in the cd driver that come with it then find the driver for your webcamp and install it if it has been install befor then remove it from control panel and when finish removing it install it back. it should be ok then.
Posted on Nov 21, 2008
  • 3278 Answers
SOURCE: My Dell Inspiron 1525 wont load up
I'd suggest first removing your memory modules and reinsert one at a time.
But, I think your operating system is compromised, due to Spyware, etc.
Since your system won't boot in Safe Mode, your only other option is to repair or reinstall your operating system.
Hope this helps.
Posted on Aug 31, 2009
micromaster
  • 3614 Answers
SOURCE: i need the administrater password to my dell inspiron 1525
You said that whe you first turn ON it is a BIOS password, not a wondows password?
Posted on Sep 20, 2009
sunnylab85
  • 302 Answers
SOURCE: Dell Inspiron 1525 on board mic not working in win 7
download the driver from the maunfacturer site it will work when it is installed
Posted on Oct 13, 2009
blh31280
  • 39 Answers
SOURCE: dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Posted on Nov 08, 2009
Load screen freezes for star trek online
change the Graphik Card or replace a new Motherboard
Sep 08, 2012 | Dell Inspiron 1525 Notebook
My dell Inspiron 1525 keeps stalling when loading and then I cannot do anything at all, as it freezes up.... I am typing this from my desktop I tried to system restore it...to no avail I tried to...
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
http://technet.microsoft.com/en-us/library/bb491051.aspx
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
You can also try safe mode command prompt
After run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
If you can get the malware installed and ran in safe mode you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Apr 02, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 will not boot. it posts but will not go past the dell spash screen. tried accessing restore partition.... tried reinstalling windows from restore cd....says windows loading then hangs...
RY THIS FIRST Hold down FN KEY and POWER Button for 3 Secs to go in Diagnostics Mode (works on almost all Dell Laptops) and run the full test you'll find something wrong if its a internal issue (even if its a hard drive issues), see if that fixes it, but I'd check the CPU HS Fan (the slots where air comes out)just blow in there and you'll see dust come out, clean it out with Air Can or Air Hose at 60PSI to prevent it blowing your blades up on the fan. If its not a hard drive or cooling issue, might want to try the Memory check (Dell has laptops have memory issues from time to time) Hope this helps!
Feb 27, 2011 | Dell Inspiron 1525 Notebook
Battery not charging symbol on my dell inspiron 1525
get a ***** and lubricate it.! as you see a ***** without lubrication hurts so badly! ok so hope to hear from you
Apr 15, 2010 | Dell Inspiron 1525 Notebook
Hope this helps.
Aug 31, 2009 | Dell Inspiron 1525 Laptop Flamingo Pink
Black screen?
can you plug an external monitor and see what happens?
also while windows is loading press Fn key and f8
Mar 25, 2009 | Dell Inspiron 1525 Notebook
Display driver stops responding on Inspiron 1525
Try to clean memory modules on the bottom side of you notebook by alcogol and fabrics . Install antivirus programm.
Mar 07, 2009 | Dell Inspiron 1525 Notebook
Xp Drivers for Dell Inspiron Laptop 1525
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&SystemID=INS_PNT_PM_1525&os=WLH&osl=en
Nominally you might get a more accurate answer by going to support.dell.com and entering the 'service tag' number (on the bottom of your machine next to the 'express service code'.
This machine also includes a field in the BIOS setup program; hit the F2 key when you see the Dell logo to start the BIOS setup program.
Dec 25, 2008 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
