Question about Brother MFC-495cw Color Inkjet All-in-One MFC495CW
Brother fax machine MFC 495 CW won't print a received fax
Machine is receiving faxes but won't print them
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
This could be issues with your driver. Try to reinstall it (you can download it from the official HP website). If everything fails, try to consult with the users manual
Posted on Nov 30, 2013
    President:
  • Brother Master
  • 990 Answers
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Posted on Nov 02, 2012
  • 320 Answers
SOURCE: Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Posted on Jan 16, 2009
SOURCE: trouble faxing and receiving fax from "Brother 575"
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not receive faxes.I have not voicemail. What can i do?
Posted on Jun 01, 2008
leroyal
  • 2120 Answers
SOURCE: not connecting to fax out
Do you have a DSL or other digital phone line?
Posted on Sep 26, 2008
  • 10 Answers
SOURCE: Trouble faxing and receiving fax from "Brother 575".
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
Posted on Jan 25, 2009
  • 159 Answers
SOURCE: I have a Brother MFC 8220 incoming fax problem
Here are a few possibilities:
Does it still say "FAX" on the display? If it says "TEL" it won't answer the phone. Changing it is just a matter of pressing the MODE button, which cycles through four settings. FAX is for dedicated fax lines. If you share the line with a phone, check your manual for info about the other two settings.
In your menu settings is a place where you can set the number of rings before answering. If it's set too high, the sending machine will give up while your machine is still waiting for that 9th ring. I know you wrote that nobody's messed with it, but it's worth checking.
A glitch in the memory may be disabling reception. We can reset it in the Maintenance Mode:
From the Ready state, press these buttons in rapid succession:
Menu
* [the star on the phone dial]
6
If you did all that in under 2 seconds, the display will show MAINTENANCE. If you were too slow, you'll just be in the menus somewhere. Press Stop and try it again. You have to ignore all the error beeps while you do this; it's designed to be nearly impossible to do accidentally.
Once you have MAINTENANCE on the display, simply touch 91 and wait. The machine will clear all its memory, except your stored phone numbers. In a few seconds it will return to MAINTENANCE. Press 99 to exit the mode. The machine will go through it's entire start-up, as if you'd just plugged it in.
You don't need to use another fax for initial testing. Call it from another phone - even a cellphone - and see if it answers. If it squeals horribly in your ear, you've probably fixed it. Now try faxing to it.
If that function 91 didn't help, try something harsher. Go through the same routine above to enter Maintenance Mode, then, instead of touching 91, touch 01. That will clear all memory to the sate where it was when you first unboxed it.
If nothing above helps, it almost certainly needs a new Main Board. Replacing that on a non-warranty machine may not be worth it, but use Brother's website to find your nearest servicer and find out.
Posted on Jan 27, 2010
Cannot clear memory on brother mfc 495 cw
go to the printers and devices near the control panel of the computer , click on printer and see what is printing
cancel any task pending not completed
Sep 30, 2016 | Brother 495CW MFC-495CW Copier/Fax...
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-495cw Color Inkjet All-in-One MFC495CW Logo
227 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
