Question about TP-LINK TLWR340G Wireless Router
Cant access tp link tlwr340g gui
Everytime i access the tp link gui 192.168.1.1 its getting me to the modem gui which has the same ip address. What can i do to set up a security key on my router??
    Novelist:
  • 108 Answers
Unplug the modem network cord from the router, make shure nobody need internet access at the time.
Then access the 192.168.1.1, and it should be the router.
In the Router GUI, change it's address to somethign else.
(192.168.1.X) where X= something between 2 and 254)
Save settings and plug the modem back into the router.
Posted on Nov 02, 2012
  • 98 Answers
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
Posted on Mar 20, 2011
  • 99 Answers
SOURCE: Need help! Cannot access YAHOO
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Posted on Apr 14, 2011
  • 747 Answers
SOURCE: I cant access internet through
uplug your ethernet cord there shoud be a small button on side od router sometimes in back u might have to get a tooth pick or stick pin to push button in ok when u do this plug ethernet cord back in.
Posted on Feb 13, 2011
puertobori
  • 7733 Answers
SOURCE: I cant open my admin
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 12, 2011
SOURCE: I am using two WAN
I'm a user 4 the same load balance product, your 2 ADSL lines must have difrent IP with difrent submask than the IP you assigned 4 TP Link-TL R480t+ (10.0.1.1 in Ur case), lets say 1st line connected to the Line through a Dlink router has an IP 192.168.1.1, this will be WAN1, its config will be as follows:
WAN Port: WAN1
WAN Connection type: Static IP
IP Address: 192.168.1.2
Subnet Mask : 255.255.255.0
Defult Gateway: 192.168.1.1
MTU Size : 1500
Pri DNS: (add the DNS here)
Sec DNS : (add the DNS here)
the second line shuld be the same way with difrent IP & difrent subnet (for example IP=192.168.2.2, Subnet Mask = 255.255.255.0 - for the router connected to the 2nd line IP 192.168.2.1 which will be the defult gatteway for WAN2)
hope this answers your question
Hosean Kobara
Posted on Nov 20, 2011
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
Oct 23, 2013 | Computers & Internet
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Connected to the network but no internet access
tried to hooked up the LAN cable directly to the modem bypass the router if you can get an internet access there.
Nov 02, 2012 | TP-LINK TLWR340G Wireless Router
How can I get back to the factory default settings if I can not get a link between the router and the computer neither between the router and the internet modem...? The modem alone, works ok, but also, the...
What Brand Router do you have? If you want to reset to factory defaults, behind the router will be a small button a reset button, Push and hold that button for at least 5-10 seconds then let got this will reset the router back to factory defaults... and under the router must be a sticker where the Routers IP address should be indicated to access the GUI/Settings page.
Make sure that by trying to access the routers GUI or setting page that your are connected using Ethernet to be able to access the Routers GUI.
Once in the GUI settings Page check if the wireless radio is turned on to be able to access the router wireless to get connected to the internet.
I hope this helps.
Oct 09, 2012 | Computers & Internet
I have installed my new TP-link wn350GD and installed the driver included but stilll i cant connect to the internet. i tried updating to a latest driver but nothing happens.. It actually detects wireless...
in your network connection, there is an Internet protocol(tcp/ip) double click it. put in obtain ip address automatically. same in dns server then ok.
If not work, configure it manually by using your laptop copy the ip addresses in your laptop, including subnet mask, and defualt gateway, and put it to your pc..
hope it can help you.
Dec 16, 2010 | TP-LINK TP link TL-WN350GD 54 / PCI / 11...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Can not setup modem:Westell 6100 to router:Linksys WRT54G
i think the best way is to describe to you the physical setup first. so you have a computer, a modem, and a router. the setup should be like this: from the walljack, the phonecable is connected to the 6100, make sure there are no micro filters connected between the walljack and the phone line because it will not allow you to connect to the dsl. from the modem, the data/internet cable at the back of it, using an ethernet cable, should be connected to the router. and at the back of the router E1 to E4, another ethernet cable is connected there and the other end of the cable is to be connected to your computer. you are right in bridging the modem, the reason for that is because both the westell 6100 and router have GUI's or Graphical User Interfaces, in short, they each have their own virtual brain. you will not have a connection if both of them have this GUI thing, so you need to bridge your westell 6100, so that the only GUI active is the routers. to bridge the modem you may need assistance from tech support of your ISP provider. assuming that's done, light status in your 6100 should have a solid DSL light. for the router, it should have lights in WAN, WLAN if you want to connect wirelessly and E1 to E4, whichever ethernet port you're using for a wired connection. you have to access the GUI of the router to make sure you have a routable WAN IP Address. As for the IP address in your computer, it should be a 192.168.x.xxx type of ip address. this is the LAN IP Address. Basically you need to have routable WAN and LAN IP Addresses to be able to connect online. you will need to configure the GUI of your router to be able to do this. for that you may need assistance from tech support of the router or if you can follow the instructions in the manual, by all means do so. the most important thing in this setup is bridging the modem.
Dec 20, 2008 | Computers & Internet
TP-LINK TLWR340G Wireless Router Logo
597 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
