Question about Plumbing
Where do i prime a goulds j5 pump from - Plumbing
3 Suggested Answers
  • 126 Answers
SOURCE: how do i prime a gould jet pump
turn pump on,pour water in the 3/4 plug on the top of pump.feathering the valve so its not open all the way.
Posted on May 17, 2010
pump will not kick on all the time
Posted on May 05, 2013
Why will well pump lose its prime
George:
There is a packing or valve in the pump that is supposed to keep water in the pump. Either a packing (O ring) or a one-way valve has failed. If it is a "one way valve" there may be a piece of gunk holding the valve open allowing the prime to drain out of the pump.
May 19, 2015 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Impeller removal
been a long time but think it is just screwed on
Feb 23, 2015 | Pool & Spa
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
HOW can I tell if a Goulds jet pump needs replacement?
pull the foot valve as it takes very little to allow the water to drain back out. Personally I would replace all pipes in the hole with heavy duty /high pressure plastic agricultural irrigation pipes
Aug 17, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
What is the impeller
The impellor is that blade attached to the motor shaft and has curved blades (some exposed others in a two sided unit) that throws the water from the center and out the outlet hole.. IT can be keyed on but mostly they are threade4d on with L.H. thread. When you split the housing that is what you will be looking at
Jan 29, 2013 | Goulds Pumps Goulds gt10 1 1 Phase...
How to prime a gould j5 well pump no plug on top
you have to have electric power to use a jet pump more info needed as to what is going on
Nov 04, 2012 | Jet Flo 04325143A Marine Heavy Duty Water...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
