Question about Toshiba e-Studio162D Copier
I have sharp AR-5127 copier and there is an error code H4-00 on the screen how can i get rid of it
    New Friend:
Hi My Error is
code h4-00
sharp AR-5127
please help me
Posted on Aug 12, 2014
Sharp copier AR-5127 displays H2-00 how can I solve this problem
Posted on Nov 19, 2009
    Novelist:
  • 148 Answers
The error code indicates a fuser problem
to reset this do the following:
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
if code comes up again after you do this then fuser lamp needs rplaced or a fuse
good luck
Posted on Jan 04, 2009
I would like to have the production date for ar 5127 & the yield for drum , devloper & toner .
best regards
Posted on Feb 14, 2009
    New Friend:
  • 3 Answers
Hi My Error is
code E5-02
sharp AR-5127
please help me
Posted on May 27, 2014
2 Suggested Answers
  • 30 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Posted on Feb 25, 2009
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Jan 16, 2009 | Toshiba e-Studio162D Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Error messsage cal for service E1-88 from sharp AR-5127
Unplug the Machine, remove the board you installed, re-seat the board,
make sure everything is connected, turn machine back on..
This is what the Manual says:
IMC PWB communication trouble (Timeout)
Check the connectors of the IMC PWB
and MCU PWB.
Check the grounding of the copier.
If you need further help let me know..
Oct 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Toshiba e-Studio162D Copier Logo
1,778 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
