Question about Electrical Supplies
Briggs and stratton 01654 generator won't start
FRANKSFIXIT
  • 72 Answers
SOURCE: Coleman Powermate 6250 generator
My answer:
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Customer Service: US: 1-800-445-1805 Mexico: 011-52-5553-660800 Canada: 1-877-501-0090 Technical Service: 1-800-445-1805 or Email: At productservice@powermate.com and a service representative will personally respond to your inquiry Service Centers: Click here to find your nearest service center in the US or Canada FAQs: Click here to find answers to our Frequently Asked Questions Product Manuals and Parts Diagrams: Click here to find your product manual or parts diagram Register your product: Click here to register your product.
Posted on Sep 05, 2008
SOURCE: Briggs & Stratton Burnt Brushes
I did find out that the inner slip ring was worn down. Still unknown why and the repair tech we took it to twice just replaced the brushes and never looked at the slip rings.
My solution, which has worked for over two months now (knock on wood) is as follows:
The slip ring on this unit can only be replaced by replacing the whole rotor assembly. I looked at the width of the brushes and the width of slip rings. The slip rings are twice as big as a brush. The solution was to move the brushes outward by one brush length. In order to do that, I had to turn the brush assembly around because of the extra plastic on the unit and space it out one brush length. Note: Still hook the wires as if the brush assembly was not turned around.
I used an old brush assembly and cut the two areas where the screws go through to make my spacers and it works perfectly.
Posted on Dec 03, 2008
CarlGehrke
  • 169 Answers
SOURCE: stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Posted on Mar 15, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Generator won't start
model# 1971 starts on first pull runs about 3 minutes and cuts off
Jun 30, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Jan 16, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
