Question about Epson Office Equipment & Supplies
Hp deskjet f4435 wont print in color - Epson Office Equipment & Supplies
ctf1800
  • 4402 Answers
SOURCE: Color Printing Problem
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
Posted on Jan 09, 2008
SOURCE: my HP Deskjet D2360 printer wont print
i have a problem on my HP deskjet D2360. I already install the driver but the printer are not responding. what can i do to solve this problem. help me
Posted on Sep 03, 2009
SOURCE: My hp deskjet F380 wont print
after the self test of ink then press scan
Posted on Feb 02, 2010
  • 903 Answers
SOURCE: my HP Color Laserjet 3550 Printer wont print black
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
Posted on Jun 09, 2010
  • 41 Answers
SOURCE: i have an hp deskjet
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to
BW and not color in the configuration menu. That should permit you to print in BW only.
Posted on Mar 22, 2011
Hp Deskjet F4435 Error after refill?
LOOK ON MANUEL THAT CAME WITH PRINTER FOR TROUBLESHOOTING THIS PROBLEM OR CALL CUSTOMER SUPPORT
Jan 21, 2016 | HP Office Equipment & Supplies
How do I get my hp deskjet f4435 printer to scan? it will copy and print but not scan . when I push the scan button it does nothing
Hi
A good idea would be to follow the link below, its takes you to the HP website and small program that you can install and run a test on your printer setup to isolate the problem. I suspect it will be a simple driver not being loaded on you computer.
Try the HP Print and Scan Doctor for Windows
Thanks
Sep 28, 2014 | HP DeskJet F4435 Power Supply Adapter Cord...
I have an hp deskjet 940c. the colored ink is out but there is plenty of black ink however the ink light is flashing and it wont print. do I need to replace the colored ink in order to print something or...
Mar 22, 2011 | HP DeskJet 940c InkJet Printer
Why wont the print when you put a new color
check the cartridge expiration date, and be sure that it is genuine
Mar 22, 2010 | HP DeskJet 2600 InkJet Printer
Feb 02, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet 712c prints only blank
I had the same problem and what worked for me was to make a PDF and then check the box "print color as black" I only say this is a fix because I was desperate. I realize this is a time consuming workaround. also if you are going to do this make sure that your printer settings are for Color but then the print color as black box is checked. hope that helps.....
Jan 25, 2008 | HP DeskJet 712c InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
