Question about Ovens
I have a Bosch Oven model HDI7052C/03 that I need to change the display/control board but I can't seem to figure out how to remove the rotating knob. There isn't a hex screw on it. Thanks for your hel
  • Ralph Leoni Nov 02, 2012
    Solved. I was able to pull the knob out by using a rubber/silicon jar clamp.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Push and pull in 1 movement
Posted on Nov 01, 2012
  • 22 Answers
SOURCE: retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Posted on Jul 02, 2007
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
  • 1314 Answers
SOURCE: Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Posted on Jan 16, 2008
SOURCE: Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Posted on Mar 07, 2010
Testimonial: "I appreciate the response to my problem. Although it is not the fix that is needed I know someone else is dealing with the same problem."
  • 17 Answers
SOURCE: i need a user guide for a bosch oven model Bosch
Here is the link to the PDF:
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rkfgKGdcdcso0pdmdb---E0C&UMOBID=rkfgKGgcdcso0pdmdb---E0C
Posted on Jul 30, 2010
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Apr 07, 2012 | Bosch Ovens
Takes long to reach it's temperature
Hello there
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 09, 2010 | Fisher and Paykel OS302SS, Stainless Steel...
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
Thermador model sc272t oven 2 doors have dim display
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Retractable function selector knob stuck
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Ovens Logo
128 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
