I have just changed the double solenoid inlet valve on the wma35,which way round do i connect the pipes back up.?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
There should be markings near the connections for hot and cold.
Posted on Nov 02, 2012
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 1073 Answers
SOURCE: Changing the water inlet valve
remove the top, the water lines from the house connect to the water inlet valve, you can see it near the top with the top off
Posted on Apr 29, 2008
  • 1462 Answers
SOURCE: I have just disconnected the
inner one is hot and outer one is cold.
to check after fitting hoses, put on rinse program and only cold water should come in. if hot water comes in then you have the hoses wrong way round.
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Posted on Jun 24, 2009
  • 104 Answers
SOURCE: Water has started to seep from where the water
To help the joint seal use a bit of gasket sealer at the joint first before assembly. Use the type of instant gasket for automotive purposes, NOT SILICONE SEALER as you want to be able to remove the joint again if necessary in the future.
Posted on Feb 17, 2010
The water to my whirlpool freezer and ice is not coming out. american type ?
I would check the water inlet valve the coils may have gone bad test them for ohms and for voltage
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Mar 23, 2015 | Whirlpool Refrigerators
I have a Kithenaide refrigerator and the pressure keeps cutting out on the water dispenser I have replaced the dispenser moyorhe but this did not work I have also replaced the filter twice not sure what...
i WOULD CONSIDER CHECKING THE WATER INLET VALVE FOR OHMS AND FOR LIVE VOLTAGE
AS YOU MAY HAVE BAD COILS
Mar 23, 2015 | Refrigerators
Need a copy of the electrical schematic to check why the icemaker does not open the valve to let weter into the ice tray
Mar 03, 2015 | KitchenAid KFCS22EVMS Stainless Steel ...
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
KSSC48QMS01 water drips from the feed tube for the ice maker in the freezer compartment how do you access the water valve under the fridge?
Hi carey_ritche,
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Before testing the water inlet valve, unplug the refrigerator to avoid an electrical shock hazard.
-->The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
-->Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
-->Test the water inlet valve for continuity using a multitester. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | KitchenAid KSSC42FMS Side by Side...
My Hotpoint WMA35 leaks water internally into the drum when the machine is not in use ?
The inlet water solenoid valve is faulty and must be replaced. usually it's right under the top cover where the inlet hose enters the machine. An easy DIY repair but remember to disconnect the electricity and water supply first.
Mar 09, 2011 | Hotpoint WMA35 Front Load Washer
Dishwasher is running through the cycles, but no water is being pumped into the unit. water supply is fine. Is this a common pump problem?
This is either the inlet valve (solenoid valve) or the timer. Water is not pumped in, it flows in under it's own pressure when this valve opens.
On the solenoid valve there are two electrical connections, you could remove these (often spade connections) and connect a mains supply - if it opens then the valve is fine so it is the timer.
A solenoid valve is a cheap and easy to swap component and any DIY'er can do it. It is located right by the inlet pipe (it is part of the inlet pipe assembly) the screw part which the cold water pipe is attached to is the solenoid inlet valve.
Jan 01, 2011 | Dishwashers
LG washing machine intellowasher 7 kg wd-8050f showing no inlet frequently even after cleaning the inlet connection point
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Jan 19, 2010 | Washing Machines
I have only bcold water feed but washer has hot/cold do i need 2
If it is a hot and cold fill m/c, what you need is a fitting that is referred to as a" Y" piece..To fit it, connect the straight leg of the "Y" piece to the cold supply tap, and then fit a hose to each of the two outlets, connecting each of these to the 2 inlets on the valve to the washer..
It will then fill with water, regardless of the programme you select.
You can purchase the "Y" piece connector from most hardware shops, or B&Q, and the like.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint WMA35 Front Load Washer
F20 Error Message
"F20" is a water inlet problem. This indicates you have insufficient water supply for the washer. Whirlpool is the manufacturer of your washer and they recommend that you unplug the washer and check the following:
1. Check water faucets to ensure they are completely turned on.
2. Check the inlet hose screens where they connect to the washer. The screens can clog with sediment over time and require cleaning. This can be a problem if you live in an area with well water and/or hard water.
3. Ensure the inlet hoses are in good shape and are not kinked.
If you check all the common sense items first and the problem still persists, you need to check the water inlet valve. To access, you will need to remove the top panel of the washer by removing the three screws that hold it in place. Once the screws are removed, the panel slides back, then off. The water inlet valve is located in the left-rear of the washer just prior to the dispenser. Double the electrical connectors to make sure they are not corroded and double check the hoses that run from the inlet valve to ensure they are not kinked. A resistance check of the water inlet solenoids (with the connectors removed) should read about 800 ohms. If the solenoid readings are abnormal, replace the valve.
Please post back if you have questions or require further assistance. I hope you find this information helpful.
Jun 12, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
