Question about Singer 3820 Mechanical Sewing Machine
How do you attach the needle clamp thread guide
I bought a Futura XL400 second hand and it was missing the needle clamp thread guide. I ordered a new thread guide and I want to attach it on my own but I can't see where it is supposed to be secured. Can you instruct me on how to attach my needle clamp thread guide to my futura xl400?
  • 23 Answers
SOURCE: Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Posted on Mar 31, 2009
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for singer futura 2000
SINGERCO.COM
It is available at the link above for $15 - there is no longer a free download.
THanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 20, 2009
SOURCE: Singer Futura 250 under XP - embroidery unit won't move
Could one of you send me a copy of the Futura installation software? I can't find mine and can't use my machine to embroider! Help!
Posted on Dec 10, 2009
  • 64 Answers
SOURCE: I have a Singer Futura CE-150 and it keeps
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Posted on Dec 22, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
Futura quartet keeps shredding the top thread, help?
AVOID old or bargain bin thread--use only fresh, good quality thread. Try a brand new needle, perhaps switch to a top-stitch needle. Change to a different brand of thread. Check to make sure the top thread follows the correct threadpath and that no guides have been skipped or threaded out of order. Check that the top tension is not set too tight.
What Causes My Thread to Shred
Fraying Breaking Madeira
Another top thread shredding issue
All About Needles
Jun 05, 2017 | Sewing Machines
I have a singer futura XL580 and the thread guide either flew off or broke off. I thought I bought the right replacement part no. 086046 but can not seem to figure it out
That is because the thread guide is underneath the needle clamp, and BOTH must be removed and replaced together as a unit. In addition, the wire is held by a tiny screw in the back of the shaft. That screw also serves as the stop for the end of the needle. Take a look at the shaft right above the needle, and you'll see what looks like a grey bar--that is the screw. It's difficult to access on the back, but must be loosened first -- JUST ONE OR TWO TURNS -- to remove the wire. Then, take off the needle clamp and wire as one unit.
Insert the replacement guide inside and at the back of the needle clamp, with the hook part sticking out of the clamp. You'll see that there's an indentation in the clamp to hold it. Insert the guide and clamp as one unit, then hook the wire around the screw and tighten.
FYI - If you accidentally remove the screw (which only turns about three or four times) and drop it as I did, you don't really need it to hold the wire guide, BUT you still need a needle stop. I just inserted a toothpick when I changed needles until I could get a replacement.
The above sounds relatively easy, but you'll probably have to do some manipulating, especially the first time, and if you're like me, possibly some cussing -- but it WILL fit.
Dec 31, 2016 | Singer Sewing Machines
How to adjust timing on my sewing machine
There is a possibility that your needle depth is not correct. IF the needle doesn't go down far enough into the bobbin case when sewing, the hook can't complete the stitch every time under sewing speed. Please take your machine in to a authorized repair shop. These repairs are multi-layered and you more than likely don't have the proper gauges and spacers to correctly set the timing on your machine. The needle depth has a measured setting inside the repair manual we aren't allowed to own.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Oct 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
How do I reattach needle threader parts on Singer Futura XL 400?
I've done this, and it's a pain, but can be done. Let me also tell you that quite a few users have broken theirs and just used the machine without it, but others said that they had to replace theirs. First of all, the wire guide is held UNDERNEATH the needle clamp, and what you have to do is insert them back in one piece. That is, remove the clamp, insert the end of the guide, then push them together on the shaft as one unit. The end of the thread guide sticks up over the top of the clamp in the back. There is a very tiny screw there that's supposed to hold it, but most machines are produced without the end going underneath that screw--they just let the needle clamp hold it. That screw is VERY tiny and VERY difficult to access, and will come out completely after only a few turns. Worse yet, it serves as a "stop" for the end of your needle, so if you lose it, you'll have to use something like a toothpick to "stop" the end of the needle until you can replace it. ASK ME HOW I KNOW! It is easier to deal with if you put the machine on its side when you do this.
Sep 21, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Twisted wire guide for the thread above the needle
Slide it onto the needle clamp from the bottom before you attach the needle clamp to the needle bar.
Mar 14, 2014 | Brother XL-5130 Mechanical Sewing Machine
How do you thread the XL400
Take a look at page 6 of your user's manual. First, is important that your bobbin be unwinding in the correct direction (a picture is right on the machine as well).
On all machines, the thread needs to be "caught" in the area on the bobbin case at the bottom, so that it can exert tension on the bobbin thread. The slot on your needle plate is most helpful in lining the thread up, but personally, I don't then put it in the thread cutter--I find that the thread is too short when I do that. I simply put it through the slot and lay it above that, and then bring the needle down to draw the thread up above the needle plate.
A PDF version of your manual is in the \Manual directory where in installed it on your hard drive, and you can also download one free at the Singer Futura support site.
Jan 10, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Futura xl400 , top thread is not showing on the embroidery , only the bobbin color
Sorry to ask, but did you make sure the machine is correctly threaded. If I am not mistaken with the new smart threading system you need to hear a click when going down to the needle. If not the machine is not moving the needle correctly to be able to pic the bobbin thread. Also try to change both threads, (bobbin and upper thread). Some brands are better than others.
Dec 03, 2013 | Singer 3116 Simple
I bought the SINGER FUTURA XL400 in august. It sews,monograms an embroiders. Sews like a dream with no issues. The monogramming part has me at my wits end. It skips stiches, leaves big loops an looks bad...
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
Apr 08, 2017 | Singer Futura Xl-400 All-In-One Sewing And...
My Brother XL5130 Needle Clamp Body felt out while I am sewing something. I do not know what is missing. I found 4 things in my hand Clamp Body, Pin,Clamp side screw & threads guide. some one plea
There is a hidden screw just that looks like a hole beside the screw that hold the needle... loosen it with # 8 allen key (pretty small) then you put the curved wire back in its hole, then you can put it back on the arm, then screw back the allen screw as tight as you can, this should do the trick worked for me ... I was tring for days to fix it back on but wouldnt go in...this invisible screw was to tight... Hope it helped !
Jul 19, 2012 | Brother XL-5130 Mechanical Sewing Machine
It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer 3820 Mechanical Sewing Machine Logo
79 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
