Question about Hotpoint Dryers
How to deactivate child lock on hotpoint tvf760, 6kg aquarius tumble dryer
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Get this user manual.
Posted on Nov 02, 2012
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
  • 1462 Answers
SOURCE: Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
Posted on Jul 23, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
My hotpoint aquarius tvf760 tumble dryer keeps flashing and saying error-07........ Has it died?
Not really, just a bit sick. I found this
F07 Lower tumble dryer element failure
  • Check security of module connector J4
  • Test between pins 4 and 3 on J4 (approximately 48 Ohms). If open circuit, test lower element and wiring between J4 and the heater.
Nov 27, 2015 | Hotpoint Dryers
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
Hotpoint wf860 stuck on child lock
Hello
To deactivate the child lock function, press and hold the 'Child Lock' button for 2 seconds. Ypu will then hear a beep and the child lock icon will go out.
Feb 07, 2012 | Hotpoint Washing Machines
WMF940 Child lock will not deactivate?
unplug the machine completely and plug it back in. Wait a second & it should deactivate.
May 25, 2010 | Washing Machines
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Tumble dryer drum won't turn
Jul 06, 2009 | Dryers
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Dryers Logo
152 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
