Question about Generac Power Systems Electrical Supplies
Generac 5793 Ix 2000 surging
Also the unit surges up and downd very bad when starting a microwave oven. Once started the oven works fine. It seems to do the same thing with other loads alos. Seems like the unit is not responding quick enough. The other question is what is the proper idle mixture setting? Thanks
  • Jordan Lee Apr 23, 2013
    Correction. 195 Ohms not 150
  • Henry Mar 19, 2014
    Jordan: Your the man! Thank you very much for your help!
  • 24 Answers
It sounds as though there is an issue with the carburetor. If the unit is "surging" with no load I would recommend thoroughly cleaning the carb. It would also be a good idea to test the fuel pump. Per Generac you need to disconnect the fuel line leading to the carb and pull the starter rope over to see if adequate fuel is flowing. If none of this is the issue try testing the stepper motor on top of the carb. If you unclip the wire and use an OHM meter all wires should test at 150 ohms. to test place on test lead on the blue wire and move the other lead to the remaining four wires. The should all ohm out to roughly 150ohms. if this is not the case you need to replace the stepper motor.... Before you do any of this you should check for fresh fuel, a good spark plug, and proper compression.
Posted on Apr 23, 2013
SOURCE: McCulloch 11HP FG6000MK surging
I just came across this post. Hopefully you have it solved. But for others who may run into this problem here is my advice. This model has a low oil sensing system. Over time the oil breaks down or gets contaminated. This can cause sympoms very akin to carb issues. I'd check this 1st as its the easiest fix. Drain and replace oil to the factory recommended specs. Make sure it is to the proper level. Your not finding any carb issues makes this almost a sure thing. DO NOT DISCONNECT or DISABLE the sensor or you defeat its purpose.
Posted on Jan 12, 2010
  • 623 Answers
SOURCE: Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Posted on Mar 17, 2009
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
  • 27 Answers
SOURCE: Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
Posted on May 08, 2009
  • 47 Answers
SOURCE: generac 4000XL. engine dies when idle control switch is thrown.
there is some problem in your AMF/ATS pannel
Posted on Sep 22, 2009
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Aug 27, 2015 | Generac Power Systems Generac 5793 Ix 2000...
How do I fix this problem
You are drawing to much power and if your not drawing any power and that light is still on then the breakers in the gen are toast
Oct 12, 2014 | Generac iX2000 iX 2000 5793 Portable Power...
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Power surge
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Apr 26, 2013 | Microwave Ovens
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
what a **** generator, worked for 100 hours and now wont start anymore.
did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
Apr 02, 2012 | Generac Power Systems Generac 5793 Ix 2000...
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
Electrical Supplies Logo
343 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
scj103
richie46
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
