Question about Singer Sewing Machines
How do you attach the needle clamp thread guide
I bought a Singer Futura XL 400 and it was missing the needle clamp thread guide. I ordered a new thread guide but I can't see how to attach it.
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: Singer futura 920 sewing machine
I have this machine for more than 30 yrs-- when this happens, the top thread is not pulled through the little disks correctly when you go up before getting to the arm. Here is a threading diagram
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_900_futura_threading.htm
Posted on Mar 14, 2009
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
Posted on Feb 13, 2010
SOURCE: threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Posted on Feb 14, 2010
  • 1116 Answers
SOURCE: Singer Futura II - Model 920
This happens when we forget to have the presser foot raised when threading.
What looks like the fault of the bobbin is actually the top thread not forming a tight stitch with the bobbin thread.
When the machine is threaded with the foot down, the tension control is closed and the thread cannot enter the control as it should. When you begin to sew, the tension control cannot do it's job.
If the machine is already threaded, lift the presser foot and pull about 10" of thread from the needle, or re-thread the machine with the presser foot up.
Posted on Mar 14, 2010
How do I reattach needle threader parts on Singer Futura XL 400?
I've done this, and it's a pain, but can be done. Let me also tell you that quite a few users have broken theirs and just used the machine without it, but others said that they had to replace theirs. First of all, the wire guide is held UNDERNEATH the needle clamp, and what you have to do is insert them back in one piece. That is, remove the clamp, insert the end of the guide, then push them together on the shaft as one unit. The end of the thread guide sticks up over the top of the clamp in the back. There is a very tiny screw there that's supposed to hold it, but most machines are produced without the end going underneath that screw--they just let the needle clamp hold it. That screw is VERY tiny and VERY difficult to access, and will come out completely after only a few turns. Worse yet, it serves as a "stop" for the end of your needle, so if you lose it, you'll have to use something like a toothpick to "stop" the end of the needle until you can replace it. ASK ME HOW I KNOW! It is easier to deal with if you put the machine on its side when you do this.
Sep 21, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Singer futura xl 400 problems
Skipping stitches are caused by a bent or poor quality needle, and never by software.
Use only Schmetz needles if you want good results.
Use Classe, Singer, Unique, Tailorform etc if you want poor results.
Mar 14, 2014 | Singer Sewing Machines
I have a Futura XL-400 and when I am embroidering it keeps breaking the thread at the needle area. I hear a noise which sounds like its coming from the bobbin arean then the thread breaks and its also
try these suggestions
change the needle
check the needle plate for burrs
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 11, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
I bought the SINGER FUTURA XL400 in august. It sews,monograms an embroiders. Sews like a dream with no issues. The monogramming part has me at my wits end. It skips stiches, leaves big loops an looks bad...
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
Apr 08, 2017 | Singer Futura Xl-400 All-In-One Sewing And...
It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
