Question about Bosch Nexxt 300 Series WFMC2201UC
Can your washer front load run off a portable generator power
Plugged washer into a cord from my portable generator and saw a digital readout for the timer and then it went blank. Cord does have a ground bar on it. Tried again ten minutes later and I get nothing on the screen
    Top Expert:
  • Bosch Master
  • 9,472 Answers
You probably fried the control board. The older machines would work fine on a generator but the newer ones are sensitive to power fluctuations.
Posted on Nov 02, 2012
  • Carl wendler Nov 05, 2012
    I found out that the voltage fluctuation it won't run. Power came back on and washer is fine. Thank you
  • Richard Roth
    Richard Roth Nov 05, 2012
    Good. I'm glad you are getting back to normal.
How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Mar 27, 2016 | Powerboss 020309 3000 psi 2.5...
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
I just bought a Briggs and Stratton pro series model # 30338 10, 000 watt I was trying to run my clipper masonry saw that has a 23 amp 208 -236 volt 3700 watt single phase electric motor. It ran it with #6...
There is just too much resistance in that cord. Get a 12 gage extension cord. And yes I think you burned out the generator due to severely overloading it.
Mar 02, 2017 | Electrical Supplies
I HAVE POWER BUT THE CONTROL PANEL HAS NO POWER
see this causes and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Oct 02, 2012 | Maytag Neptune MAH6500A Front Load Washer
Hook up electrical cord and run a TV, Fan, and it burns up the load (TV, fan, etc.).
Check what your voltage / frequency is coming out if the unit, generator outlets.
Jul 12, 2011 | Coleman Powermate Premium Plus 6250W...
Every tme I plug in an extenson cord the circuit breaker trips.
Try a different cord and see if it works ok. If the circuit breaker trips without anything plugged into the extension cord then the chances are that there is a short in the socket of the cord or it is wired incorrectly.
Apr 27, 2011 | Briggs & Stratton Briggs and Stratton...
The pull cord is locking up and wont allow it to turn over
you need to remove the front cover where the pull start Cord is and check for anything that is blocking the Cord a broken spring under the Cord wheel can cause this as well
Sep 23, 2010 | Briggs & Stratton Briggs Stratton 6200...
The Kenmore Elite washing machine gets an F1 code on the digital readout then stops. Once the start and stop buttons are cycled a couple of times the machine starts running again.
Check to see if the screens for your hot and cold water connections are plugged with grit.
Or else the problem might be due to factory defect in the control circuit board of this washer.
Mar 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Apr 16, 2009 | Hammering
Coleman 6250 gen
Assuming there is nothing wrong with the generator, I'm not sure what the Amp rating on a 1 hp compressor is, but starting currents can be 5 or more times the rated current, especially for starting heavy loads like compressors. While the motor only needs it for a short time, if it doesn't get it, it ain't gonna start. If you really need to run this compressor off this generator, one possible solution is to see if the compressor motor has connections inside to wire it for 240 volt operation. I realize in theory you should have available the same full power rating from the generator at 120 v and 240 v. However, many times a motor will still start more easily on 240 than 120, for the same reason that automobile starters went from 6 volt to 12 volt. If you do change the voltage to 240, BE SURE TO CHANGE THE POWER CORD AND PLUG ON THE COMPRESSOR!!!
As a side note, I have one of these generators I purchased as "refurbished", and it is flakey. It works, mostly, but not exactly right. I'm working on it. So anything COULD be wrong.
Oct 05, 2008 | Coleman Powermate Premium Plus 6250W...
Bosch Nexxt 300 Series WFMC2201UC Logo
63 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
