How can i get my tv to chane from cable to air
Iwant to change from cable to over the air antenna
  • 127 Answers
Read manual and follow instructions.Or go to menu select Tuner
Selet cable or antena and the channels
Posted on Nov 02, 2012
How do i hook up a 32 inch Sansui TV to an antenna
After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
Oct 22, 2015 | Sansui Televison & Video
Moved tv from one house that had cable to another that has antenna will not down load channels
change the input from cable to antenna most of the over the air stations do not download .
Jun 20, 2015 | Philips Magnavox 26MF605W17 26-Inch...
How do I change from Analog air to cable?
there are no analog over the air channels, only digital ones, there should be an input button, maybe even an antenna select button on your remote, or in the set-up menu using the buttons on the front of the tv. there may also be a seperate connection in the back of your tv for cable, or over the air antenna
Oct 22, 2013 | Sansui HDLCD-2612 LCD TV
Itihave an lg tvmodel no 32lh20 iwant to switch from cable to air how do ido this
go to set menu with remote and look for a setting that says cable, air/antenna and switch it but you may likely have to auto program the channels after that.
Nov 01, 2012 | LG 32LG30 32 in. LCD HDTV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
I am tire of cable and want to use an antenna, I have hooked an antenna to the tv checked the hook up and it is secure, but am getting no signal...I have been trying to find a place to change from cable to...
After u hook up the antenna source like a digital or a roof antena to the tv.Used ur remote go into the tv menu.Goto SETUP,go down to CH.Pick AIR enter and scan for free air DTV channels.
Feb 25, 2011 | LG 32LG30 32 in. LCD HDTV
I have this tv and the antenna wire got stepped on and broke, is there a solution wth going in and replacing the connector. I was thinking and adaptor fron antenna cable to rca connector? is thiis...
well yes and know...let me explain.at theshop this is a very common occurence that we see alot... this connector is atached to a thing called a tuner. the tunner is what the tv use to select the channel. withhout this you cant change channels what can be done is atach a vcr and then use the rca inputs.. you will have to change channels using vcr.some cable boxs do this also again chaning through the cable box. this can be repaired depending how much damage has been done our shop ussaly charged around 85 dollars to repair the connector.
Dec 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
