Question about IBM Office Equipment & Supplies
Ibm proprinter iii paper size
How can i fix paper tear line i am using oki microline 320 turbo 9 pin printer for tag printing. window xp printer drive: okidata ML 320 turbo/D (IBM) & IBM proprinter III. paper size: tag (width 20.32cm, height 1.91cm) program: personal made by foxpro (QUICKCLEAN) after tag printing, many paper come out. in printer devices settings, tractor feed "Letter" the over come out paper size is same as Letter size. how can i fix exact tear line? please help.
Windows xp printer driver for Oki 320
Install an IBM Proprinter III driver. This driver is built into your Windows system and can be found in the Add Printer Wizard.
the computer will install that driver and it will make this unit compatible with windows xp
Oct 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Lines on doc wont print
you got a driver for this very rare printer now?
What you give her IBM proprinter II protocol?
Should be a Proprinter III type
Go download here:
http://my.okidata.com/PP-ML320Turbo.nsf?opendatabase
Don't forget my four stars ;)
May 05, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320
Use a IBM proprinter driver not Proronter 111 driver.
Hope this helps.
Dezzi
Apr 09, 2008 | OKI MICROLINE 520 Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320 Problem...
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Feb 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320 turbo 9 pin printer
What driver are you using, you should try the IBM Proprinter Driver.Hope this helps.
Dezzi
Feb 11, 2008 | OKI MICROLINE 320 Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
35 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
