Question about Nintendo Super NES Console
My nintendo wont work the controllors i bought new ones
I bought new controll pads for my super nintendo but it wont let me play the game
  • Nintendo Master
  • 427 Answers
Well it sounds like the controllers might be defective then you could clean the controllers out with rubbing alcohal and qutips and soft cloth and use a tooth brush too to clean them out. Buy controllers from lukie games then or jj games.
Posted on Nov 02, 2012
  • 43 Answers
SOURCE: Super Nintendo won't show any picture or sound even though it reads a signal.
Try pushing down and back lightly on the cartridge while turning it on.Used to work for me.You can also clean the game contacts with rubbing alcohol.Hope this helps...
Posted on Feb 21, 2008
  • 1019 Answers
SOURCE: Super Nintendo Start/Select Button not working all the sudden
your problem will be with the mating surfaces of the switch contacts themselves.
i,ve cleaned several console hand-pads. to find that sweat and food debris mixed together, get under the contact pads.
this is the small piece of carbon ( mounted under the silicone rubber pad ) inside the controller.
these should be wiped with a cotton bud, swabbed in a small amount of lighter fluid ( or methylated spirits ) and wiped clean.
re-assemble controller.
check the cable for signs of wear, also the controller port mating surfaces should be shiny copper connections. if these are not mating with the controller, then no signal is being transmitted between the pad and input ports.
look carefully, if any pins are lower than others, take a fine electrical screwdriver or needle, and gently bend the pin upwards, so that they all align at the same height.
Failing this, you have faults on you controller port input sockets.
these can be replaced, as they,re ribbon cabled to the mainboard. this is a job if your electrically competant.
Hope this helps.
Mike @ Compurepair.
p.s if it was simple, everyone would be doing it :)
Posted on Feb 23, 2008
  • 916 Answers
SOURCE: why aren't my games playing on the nintendo fc twin?
The FC Twin connects through an RCA connector, and can be hooked into a surround sound system. When using stereo and surround output from these systems, NES sounds and music may seem very different from their typical mono output. Using output modes that properly generate mono sound, either through a single center speaker or cloned to multiple speakers, the sound output sounds mostly identical to the original NES. The FC Twin does not produce some sounds faithfully, even with mono output; sound effects in the Super Mario Bros. series games will for example immediately seem different. Nevertheless, some later models of the console produce NES sound much more faithfully than units made closer to launch. Recent models produce sound with complete fidelity.
all this can be found here
http://en.wikipedia.org/wiki/FC_Twin_Video_Game_System
Posted on Jan 18, 2009
  • 232 Answers
SOURCE: my super nintendo screen is black and wont show
Try it on another TV, make sure the AV switch isn't in wrong positon, try another lead like a SCART lead if you're not already.
Posted on Dec 14, 2009
  • 291 Answers
SOURCE: I recently bought 'Mario Paint' for my
I think that you need a mose for it to work not a controller then.
images?q=tbn:and9gcskx_izsc6otut8u5zhvoj-azwe92n9xigehrwuno-htbgbzevn
Posted on Oct 11, 2011
The super nintendo game wont release and wont play
Are you able to pull the game out manually?
The eject feature isn't necessary for the console (it just aids in pulling the game out straight.) You can pull it out manually, just make sure you don't pull it out at an angle to prevent bending or breaking the game. When you get the game out, clean it thoroughly with rubbing alcohol on a q-tip.
When you turn it on does it make any affect on your tv screen at all? If it doesn't it is probably your av cord. They do go bad over time. A new one is approx $2 on e-bay.
If you get a black screen or fuzz on your tv, it's just a dirty game or console.
Dec 11, 2009 | Nintendo Super NES Console
Wii controllers not working with new super mario game
maybe you will just need to get new controlers or a new game!!!
Nov 23, 2009 | Nintendo Wii Console
Won't Play New Super Mario Bros.
You may have a defected game, you can take it back to the store that you bought it from and ask for a new one after telling them the problem. if they wont take it back you can contact Nintendo, tell them your problem and send the game to them, they will either try to fix it or give you a new game
Oct 16, 2009 | Nintendo DS Console
Controller port or system and why...
open and clean the controller pad....or buy a new one....sometimes snes joypad goes crazy with dirty inside the buttons contacts, it gives the impression that is a defective console..but in most of the time..the snes joystick need a fix !!! Good Luck!!!
Sep 10, 2009 | Nintendo Super NES Console
Can we play gamecubegames inside the wii console, if so how?
You can do both. With internet you can download Nintendo 64 games on the wii shop channel. For game cube games enter the controller in slot one, enter the game and it's like you don't have a wii!
Note: due to the fact the the wii remote does not have enough buttons ALL N-64 games need a gamecube controller or a classical controller. Game Cube games are not compatible with classical controllers.
Apr 02, 2008 | Nintendo Wii Console
Logitec rumblepad 2 not working with nintendo emmulators
You have to program the individual buttons in each emulator. Switch to gamepad mode if applicable.
Jul 31, 2007 | Logitech Dual Action for Pc (963292-0403:)...
Nintendo Super NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
