Question about Robot Coupe Food Processors
Robot coupe cl 50 version d the machine works but after a few minutes the heat increases of the motor and then the machine stops working
4 Suggested Answers
  • 81 Answers
SOURCE: How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. capt_rick1912@yahoo.com
Posted on Jul 25, 2009
  • 81 Answers
SOURCE: Robot Coupe clicks, runs 5 seconds, stops for 30 seconds, clicks, runs 5 seconds...
The clicking noise is an internal circuit breaker or motor protector. These things are not made to be bogged down or overfed. The motor is heating up & tripping the overload, after cooloing it resets. Time to buy a new one or get the motor replaced ($600-$800)
SOURCE: I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Posted on Jan 06, 2010
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
Robo coupe CL52D would not turn on
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. capt_rick1912@yahoo.com
Dec 16, 2008 | Robot Coupe CL52D Food Processor
Robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Jun 06, 2008 | Food Processors
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
Nov 15, 2007 | Robot Coupe CL50 Food Processor
Oct 29, 2007 | Robot Coupe R100 10 Cups Food Processor
Food Processors Logo
55 people viewed this question
Top Robot Coupe Food Processors Experts
Ross Keen
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
