Question about Whirlpool WTW4950XW Washer
Washer keeps throwing belts
Hello i have this washer that keeps throwing belts from the bottom nut that holds pully keeps coming loose everything else works great just can figure out why it keeps doing this thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Out of balance
Posted on Nov 01, 2012
3 Suggested Answers
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
  • 1218 Answers
SOURCE: Water not draining out of
Good day,
It can be done but is one major project. I've added a tutorial on how to replace it. I agree with most of it but I do suggest you completely remove the pump. It will make life a lot better.
As well I would read # 41 carefully. If that BB falls out, and you don't replace it properly, the machine will assemble but not spin.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=144
Posted on Nov 06, 2010
CRANK SET KEEPS COMING LOOSE
You may try using a lock nut which may stay put. You can find lock nuts at hardware stores or Lowes, etc.
Apr 30, 2014 | Best Fitness BFSB10 Indoor Cycling Trainer
Blower motor belt
It could be belt or belt idler problem or rollers or drum has twist on it or motor pully issues .
Every part of dryer drum and motor pulley and idler and belt should be examine and run dryer without top and check it with load and without load and try to isolate problem
Dec 06, 2013 | Maytag Bravos Series MEDB850WQ Electric...
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Jun 22, 2013 | Craftsman Garden
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
HOW DO I REPLACE THE BELT TO AN AQUARIUS HOTPOINT WMA40
hello take the back off the washer at the bottom of the washer you should see the motor and where the belt goes. the motor sits on bracket with 2 nuts each side get flet tip pen and mark where the nuts sit get a spanner unloosen the nuts the motor should drop down get your new belt put it on the the large pully first and slide it round the motor and bolt the motor back in its place good luck
shaun
May 08, 2009 | Hotpoint WMA40 Front Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drive belt broke
Hello, ok if this is an older washer then you might want to call a pro. This job takes me no more then an hour to an hour and a half and I have been doing it for 20 years. This is really hard job and you might make things worse. Thank you
Dec 05, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool ghw9100l belt will not stay on drum drive pully
I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
Nov 07, 2006 | Whirlpool GHW9100L Front Load Washer
Whirlpool WTW4950XW Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
