Question about Dishwashers
The Stop LED light is lit up on my Asko dishwasher and I cannot get the dishwasher to run or the Stop button to go off, Suggestions?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Turn of electric to whole house wait 2 secs and turn on, it shud be sorted
Posted on Nov 01, 2012
SOURCE: Asko Dishwasher F2 Error Flashing
i have the same problem (F2) with my 1776. they said it was a overfill sensor. I pulled to first kick plate off but can't get to the 2nd. any suggestions on how to do this? thanks!
Posted on Jul 29, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
SOURCE: lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
Posted on Mar 05, 2009
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
SOURCE: Asko 3120 dishwasher drain pump
this is because ther is a leak from the main tank. Water goes under the main tank, where all electric motors, pipes an pump are. There is sensor in that area that trigger the drain pump. Up to 4 or 5 liters can accumulate in that area.
Only solution is to remove that water by tilting the washer on what ever corner.
Posted on Dec 05, 2009
Asko d3250 drain pump wont stop running
Most likely is activated overflow system.
This means water leaks under the dishwasher and is activated drain pump to prevent flooding. The simplest is to lean on either side the dishwasher so if there is water on the floor, that's it. Now you need to identify and repair the leaks. You can not be excluded that a defective triac by driving the drain pump placed on circuit board. It very rarely happens and some brands signals a failure by display or LED diodes .
Dado
Mar 10, 2015 | Asko Dishwashers
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Lights blinking
Jan 25, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher Odor
I would disconnect the drain hose from the sink trap and drain the water out into a pot -- just to make sure there's nothing in the hose that can't get out. Check the sink trap too to make sure it's not holding something. Run an empty dishwasher using TANG instead of dishwasher detegerent.
Sep 24, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 3230 dishwasher - not powering up
you dont really need to turn the power to the unit off. Just leav it on till you can get the swithc replaced.They are kind of difficult to do, and you can break the control panel if you dont know what you are doing. i leave mine on all the time. Good Luck!
Sep 23, 2007 | Asko D3251FI Dishwasher
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
