Question about RCA F36650 36" TV
I have an RCA F36650 36" TV that quit working after a power outage. When I first attempted to power the TV on, the power on indicator came on, but I had no picture or sound, and then after a couple of seconds the power on indicator went off. Not being sure if this was a glitch or a real problem I unplugged the TV and let it sit for a about five minutes. I then attempted to plug the TV back in. When I did this, The TV had a very high pitch chatter emitting from the rear of the set, and now I could not get the power on indicator to light, and of course still no picture or sound. So, I removed the back cover to trace the sound, the sound appears to be coming from LP03, the BIAS (B+) transformer feeding the primary to the flyback transformer? The question is, is this high pitch chatter coming from LP03 telling me the problem is LP03, or a symptom of a different failure in this circuit? And if it possibly a symptom of another problem, what could the problem be?
  • mjknfun Jan 04, 2009
    FBT? Flyback Bias Transistor? and test ring? I have an electronics background, but have not made a living this way in about 13 years. Thanks
  • mjknfun Jan 05, 2009
    no it is not still under warranty
    Genius:
  • 1,239 Answers
HI
Check capacitors 3 of them if cp150- 2200uf 16 is puffed up on top it is bad so replace other 2 caps cp114 cp120 220uf 35v. These are on the Deflection board, also resolder pinns on FBT.capacitors are green with gold writing on them. There is 2/3 on bottom First board to the left is the Deflection board next to it the one that has tuners where you hook cable to is the SSB board the board with AC Power cord is AC board
DEFLECTION BOARD has Flyback Transfomer on it has 2 wires coming from part red/black-/.one of the wires goes to high voltage trippler other one leads to focus/screen control block it has 3 controls on top 3 on bottom R/G/B
Posted on Jan 04, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 04, 2009
    you can check the three little red fuses next to the flyback transformer , but then if not that then the convergence IC's will need to be replaced and the resistors checked on it for possible replacement
  • 192 Answers
If it is still under worntee they might be able to fix it for you.
  • Michael Ward Jan 05, 2009
    Well it might be just time to get a new TV especally where everything has to be DTV by next month. If you have dish nework or direct tv as your servas provider you might not have to have the converter box for the tv.
    President:
  • 1,952 Answers
The chirping you hear is the switch mode power supply attempting to start up. It is unlikely that the resistor is the only problem. Something caused excessive current draw through that resistor.
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 04, 2009
    it does have a fuse in it you might want to check, but in most cases i
    would say the power supply in the tv has gone bad. it is hard to say
    without testing some voltages in the tv
    This is a famous problem for RCA RPTV sets. They develop problems in
    the main power supply and over time it finally give out completely.
    It can be other areas of the tv such as high voltage generator,
    horizontal or vertical deflection amplifiers or even the convergence
    systems, but it is most commonly the main power supply or one of the
    voltage regulators within the power supply system.
    In most cases the repair is expensive and often more than is
    justifiable. Typical repair costs for the power supply are $300 plus
    or minus. Repair costs for the convergence circuits is always around
    $400. Horizontal or vertical repairs usually run around $200.
    I suggest you talk with an RCA authorized service outlet before
    deciding what to do. Unfortunately, the RCA brand is not known for its
    reliability and will likely have another breakdown before too long if
    you do decide to repair it.
    If the set has an audio output on the back of the set or a headphone
    jack just use an external amp/speaker for good sound and shut off the
    internal speakers.
    You can get a pretty good sounding little system with subwoofer at the
    pc store for $20.00 and up. You may have to buy a cord that will go
    from the audio outputs into the PC speaker set, but that will be just a
    few dollars.
    If it were the high voltage only, the sound usually continues working
    normally. With no sound nor picture it is usually the main power
    supply. Common on big tube sets is the failure of the rectifier bridge
    in the main power supply. Do you know how to check it? If you have a
    vom you can see if there is any B+ voltage coming off the rectifiers.
    Or, you can pull them/module out and check it with a ohmmeter.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most TV units, with your described condition, primary suspect would be the Horizontal Out Transistor (HOT) which could be tested forward & reverse with an ohmmmeter. Likewise to test ring tested would be the FBT.
Good luck and Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Jan 04, 2009
    FBT would be the FlyBack Transformer or Line OutPut Transformer (LOPT). A ring test is check for the FBT out of circuit using an instrument that sends pulses to the FBT's primary circuit. Thereafter a comparator circuitry checks the number of damped oscillations or 'rings' produced and determines if the primary is good or not.
  • Louie  Role
    Incidentally, another responder mohammed387 has posted on the chirping sound which is the power supply. He has copied this information among others from here, here and here.
  • Louie  Role
    Appreciate the Ask Me. Pls update any developments.
    Cheers.
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
TV suddenly shut off - and now won't turn back on. Screen went totally black. When you try to turn it back on, screen stays dark, and tv has a humming sound that wouldn't shut off until unplugged. Not...
Did this unit fail after a power outage or passing storm? If so could be lost of component in the low voltage power supply circuit or degausing relay circuit. I would strongly suggest you seek help from a qualified repair center. Don not attempt to repair yourself...to dangerous.
Feb 18, 2011 | RCA F32650 32" TV
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' projection TV: will not turn on
Try unplugging the set for a full minute, then plug it back in and try again.
Sometimes this will reboot a glitched up computer.
Otherwise you will need the assistance of a professional.
www.mcveyelectronics.com
May 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
TV WOULDN'T TURN ON
it could be a blown fuse check those first if its not that something might have been fried from the power outages
Oct 26, 2008 | RCA R52WH73 Projection Television
Rca d52w20
if you had a power surge from the outage it could be anything. disconnect from the house power and try again in an hour.
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
