Question about Mio Quest Gps Heart Rate Watch
Mio Quest strap needs battery replacement - Mio Quest Gps Heart Rate Watch
I need a replacement watch strap for my diesel watch dz1505
go to a watch store they might be able to help
Sep 17, 2014 | Diesel Watches
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
May 06, 2014 | Mio 0021usblk2 Drive Petite Hrm Black...
Ebel 1911 stainless steel 18 k bezel strap broken, battery needs replaceing
Any jewelry store can replace the battery.
They can also sell you a new strap.
Anything else wrong with the watch??
Aug 29, 2011 | Watches
I have a mio watch,installed new battery.hear rate monitor does not work,much too high
Have you contacted their customer service team? They are great at resolving issues and really stand behind their product. Their Facebook page MIOWatch also has lots of troubleshooting and FAQs too.
Nov 13, 2010 | Mio Motiva Strapless Heart Rate Monitor...
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
How to change battery in Casio wave ceptor4305
If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
After battery replacement, just push the contact back into place till it fixes.
If there are screws holding the contact, just undo them.
Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Mio Quest Gps Heart Rate Watch Logo
95 people viewed this question
Top Mio Watches Experts
Jimmy Accardi
Are you a Mio Watch Expert? Answer questions, earn points and help others
