Question about IBM Lenovo ThinkPad Edge 15 Notebook
Lenovo thinkpad edge page up down and direction buttons not working
All of a sudden the arrow buttons, page up/down buttons, and the home/end buttons are not working. It is making me nuts. I guess I use those buttons more often than I realized. I've restarted the laptop a couple of times but that hasn't changed anything. Help!
  • njchicaa744
    njchicaa744 Nov 01, 2012
    There is no numlock key on this device.
  • 107 Answers
SOURCE: Ibm lenovo R51
have you check the temperature of your laptop. try 2 check on it through your bios. certain features of bios restarts itself when temp is to high to avoid from burning internal components
Posted on Feb 16, 2009
leecom72
  • 4806 Answers
SOURCE: ibm thinkpad keyboard right side is #'s not letters
You have accidentally turned on the "Num Lock", all you have to do is hit the Num Lock key to return the keyboard to normal, it is located at the top right hand side of the keyboard.
Regards
Posted on Jun 19, 2009
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
QHabib
  • 126 Answers
SOURCE: i am using a Lenovo Y500 laptop. My laptop is
Hi I suggest you update your display driver first and then update others as well. Wrong drivers and incompatible bios versions can cause many problems....
The link is directly to your lenovo website for the Lenovo 3000 Y500 laptop. Incase your model is different let me know the exact model. It will be listed underneath your laptop on a sticker with bar code.
Posted on Sep 23, 2009
Can't get my ThinkPad Edge E530 (3259-78U) to aknowledge drivers for the networking
Go to the Lenovo website click on drivers & software then enter your model number and then select your operating system and you will find all drivers for your ThinkPad Edge E350.
Jan 11, 2014 | Lenovo ThinkPad Edge E530 3259-78U...
MY BLUE BUTTONS DON'T WORK
Maybe a crumb under the Fn key. Give it a stab and see. Otherwise go to start-control panel-monitor-adjust brightness. Hope this helps.
Dec 18, 2013 | Lenovo ThinkPad R500 Notebook
E320 2007 battery replacement
Lenovo ThinkPad Edge E320?
I don't think you are referring to the Main battery......
However;
1) There is a slide button on each side of the Main battery.
Both are slid to the outside edges of the laptop, then the main battery is slid out. Out towards the outside of the laptop.
I believe you are referring to the CMOS battery.
Also known as the RTC battery. Real Time Clock battery.
From what I can see the ThinkPad Edge E330 is VERY similar to the ThinkPad Edge E320.
What you need is the HMM. Hardware Maintenance Manual,
http://www.manualowl.com/m/Lenovo/ThinkPad-Edge-E330/Manual/309892
Use the Right Arrow on the right side of the number 100, at the top; to go down through the pages.
Page 61 for Main Battery Removal/Replacement
(Starts on Page 60 - 1010 Battery Pack. Bottom of page)
Page 70 for RTC Battery Removal/Replacement
Bottom of the page - 1070 Backup Battery
As you can see you just remove the screws, (Philips. Use No.1 Philips screwdriver, or equivalent Jewelers screwdriver), for the Bottom Cover, and remove the Bottom Cover.
(It's a panel. It is not the Base Enclosure/Bottom Cover)
Then unplug the small white male plug connector, on the end of the RTC Battery's wires; from the motherboard.
Remove the RTC Battery, and replace.
This shows you in a video, but a different Lenovo ThinkPad Edge laptop.
Principle is still the same,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=PD021754
KNOW THIS HOWEVER........
Your body carries Static electricity. When that Bottom Cover is removed, all of the Static shock sensitive hardware components are exposed.......
You need to make SURE your body is relieved of Static, BEFORE reaching to unplug that RTC battery, or remove it.
Better still is to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
Average cost is around $3 to $6.
Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Example of RTC Battery,
http://www.ebay.com/itm/COMPATIBLE-Backup-RTC-CMOS-BIOS-BATTERY-CR2032-FOR-IBM-Thinkpad-02k6541-/251250253852?pt=Laptop_Batteries&hash=item3a7faea01c
Now I did NOT state that this was THE RTC Battery you need.
Just stating that is what it looks like.
Know this;
ALL of these batteries produce 3 Volts DC.
They use a CR2032 watch type battery, that is commonly used in a desktop computer.
All you need to make sure of, is the Male Plug Connector is correct.
Yep. That's it.........
If you HAVE to, you could cut the wires on the new RTC Battery, cut the wires on the old RTC Battery, and PROPERLY splice the old RTC battery's male plug connector to the new one.
Use heat shrink tubing, and solder the wires together.
Remove RTC Battery to reset a password?
Nope. Don't think so.
There should be a capacitor, or capacitors; that store a small residual charge of power -> INDEFINITELY, even after removing the RTC Battery. (CMOS battery)
CAN I be wrong? Yep. Depends on manufacturer, and year made.
Replace RTC Battery because it's no good?
Yes. Sure.
Looking at the Base Enclosure, (Bottom Cover), is part of what makes me think the E330 is very close to the E320,
http://www.pcworld.idg.com.au/review/notebooks/lenovo/thinkpad_edge_e320_129834m/397569/images?image=5
http://support.lenovo.com/en_AU/product-and-parts/detail.page?DocID=PD024121
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 17, 2013 | Computers & Internet
My touchpad seems to have competely stopped on my thinkpad edge. I turned it on and all of a sudden it wouldn't work, so i had to use the small red button above the touchpad. I checked on the cont
Hi
This could be one of several problems. The first thing to do is to make sure that the driver for the touchpad has not become corrupted. Sounds complicated I know but its not. Please follow the steps below and let me know if this solves the issue. I'm assuming you are running Windows 7 but it very similar in XP as well.
1. click on start
2. In the search box type device manager then hit return
This will open Device Manager
3 click on the little arrow next to Mice and other pointing devices
Your touch pad should be listed here.
4. Double click your device
its property box will open
5. click on the driver tab at the top
6. click on update driver (you must be connected to the internet)
7. follow the instructions and make the choise to search for the driver automatically.
This will download the latest driver for your PC and should fix thye problem. Please let me know the results.
Apr 09, 2013 | IBM Lenovo ThinkPad Edge 15 Notebook
Where can I find an owner's manual for a Thinkpad type 195243M S/N L3-FA152 06/12
Thinkpad 1952 comes up with a Thinkpad T60,
Thinkpad 195243U comes up with a Thinkpad T60 also.
Lenovo/IBM Thinkpad T60 series of Notebook PC.
IF the above holds to be true,
http://support.lenovo.com/en_US/landing.page?
Go down to the middle, and subheading -
Reference Documents
In the list underneath click on - User Guides
Under the subheading - Guides and Manuals, in the red banner; click on - Installation and User Guide
http://support.lenovo.com/en_US/guides-and-manuals/detail.page?DocID=UM010582
Read the instructions.
Under the heading - ThinkPad Series, go down to - T60, T60p
Scrolling across there are three blue - Download - listed.
Look up at the top of the chart, and click on the one correct for the Windows operating system you are using.
Regards,
joecoolvette
Feb 24, 2013 | Lenovo ThinkPad R51
Where can I get a user manual for lenovo T42
From Lenovo Support,
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Under the white - Guides and Manuals heading in the red banner, go down to - User's guide, and left-click on it.
To the right of -
User Guides (Click 'Learn More' to download) - Thinkpad,
click on the blue Learn More
In the chart on the next page scroll down to T42, T42p in the left column.
Go to the right, and under the Windows XP heading click on -
Download in blue.
On this page scroll down to -
(English) Access IBM for Windows 2000/ XP
(1rth52us.exe / 23.5MB )
Go to the right, and under the Download heading click on the black Down Arrow.
A small window will come up on the right. Click on Save File.
A small download window will come up on the left.
Allow the file to fully download, then DOUBLE-click on it.
Regards,
joecoolvette
Sep 28, 2012 | Lenovo ThinkPad T42 Notebook
I need drivers for lenovo thinkpad edge wifi
Go to the link Driver and download Networking:
Wireless LAN driver .
Thanks for using FixYa.
May 30, 2011 | Computers & Internet
My Lenovo ThinkPad SL 400 display is too dark and cant control with the brightness control buttons (Fn + Home or End keys). Once Laptop battery power was really down and this started happening after...
Your Inverter board is probably bad. It is inside the LCD unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Lenovo ThinkPad SL400 Notebook
Is there a key combination for the ACER Aspire 5734Z-4725 that will do "page up", "page down" and Home and end? I tried number lock and it seems like that just gives me the arrow...
Yes you press NumLock buttom localized superior left on the keyboard and the you can press Home (number 7 button), End (number 1 button), Page Up (number 9 button) or Page down (number 3 button)
Nov 16, 2010 | Acer Aspire 5315 Notebook
IBM Lenovo ThinkPad Edge 15 Notebook Logo
366 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
