Question about Daewoo Microwave Ovens
Mt1510w missing installation bracket - Daewoo Microwave Ovens
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
Our MT1510W micro shuts off by itself and then turns back on later whenever we start large project like Xmas candy, Why and how do I fix it or should I return to dealer?
This problem is usually caused by a blocked air vent, a clogged filter, a failed or failing internal cooling fan, or a failed or failing magnetron.
If you purchased it less than 30 days ago, I would recommend that you return it or exchange it.
If it's over 30 days but less than one year (or whatever the warranty is as stated in your owner's manual) then you would need to contact Daewoo to find their nearest authorized servicer.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find your nearest authorized service center.
Dec 06, 2009 | Daewoo Microwave Ovens
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Need installation bracket screws
You'll probably be able to find the part number either from the installation instructions. You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 14, 2009 | GE Microwave Ovens
Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
May 23, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Turn table broke
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
Feb 02, 2009 | Daewoo KOR-630A Microwave Oven
How do I install my Kenmore Microwave Oven 721.63664300 to the wall
You can usually find exploded views and order parts & manuals by entering your model number here at the Sears parts site.
Aug 13, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
32 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
