How to do a auto channel scan using a universal remote
  • Robert Nov 02, 2012
    Sorry,wrong topic
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Menu,configuration,=scan settings
Posted on Nov 01, 2012
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
Need code for Sony DVD and Sony tv and how to program it I have ge 24991 1312 universal remote
Buy a SONY universal remote.
Most universal remotes do not support SONY, but a hand full do.
Packaging should explicitly state support for SONY.
Most IR remotes can use a carrier frequency range of 30-56KHz, with most using normally 38-40KHz, or likely the GE universal. SONY is in the mid 50KHz range, other manufactures in upper 40KHz range and audio equipment Bang & Olufsen and, Kenwood use a 455KHz frequency. The carrier is what your TV or DVD is tuned to see and the codes are transmitted like Morse code for digit ones and zeros to say, change channel or play.
Short to say if you don't find an auto code scan that works then try another manufacture. Manual can be found online at manualslib if lost.
Feb 27, 2015 | Sony Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
Jan 31, 2011 | RCA Televison & Video
We are using the RadioShack 4 in 1Family Favorites universal remote with a sylvania 6727DD TV/VCR/DVD combo unit, but we are unable to get the TV menu to open up so that we can scan and auto program the TV...
Used ur original tv remote?Try website like Remotes.com to buy an exact tv original remote.Universal remotes only can do the tv basic.Open up tv menu to do within functions within the tv,more personal complex to the individual tv itself.
Sep 30, 2010 | Radio Shack 15-2142 Remote Control
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
