Question about Motorsports
Broken vacuum flap for defrost on 1997 jeep wrangler repairable?
I looked at the vacuum actuators by gas petal and found the end of the flap broken off still attached to vacuum switch can this be repaired or replaced easily
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Yes parts are easily accsessable online,check make and model
Posted on Nov 01, 2012
1997 jeep wrangler heater blowing cold airWhat's your problem?
Heater blowing cold air,indicates towards low or no coolant or the coolant flow is getting obstructed or the heater core is clogged or hot to cold moving flap/ door is stuck in cold mode. There are many possibilities, that needs to be checked. Click the link below for step by step details:--- http://technoanswers.blogspot.com/2011/10/heater-blows-only-cold-air.html ---------- This should help.Thanks.Helpmech.
Oct 20, 2011 | 1997 Jeep Wrangler
Lot53yahoo.commy jeep x 2005 a/c blows out the defrost ,did work fine then just went bad . i cant find the actuator loc or is it a vac leak ??
You've got a vac leak...somewhere.
Unfortunately, you'll have to make time to find it.
When you lose enough vacuum...the "blend door's" default position is to blow out the defrost.
I've looked for vac leaks with starting fluid, or Barryman B12.
While engine is running spray hose connections...when engine "surges"...that's where the leak is.
Hope this helps...
Aug 15, 2011 | 2005 Jeep Wrangler
97 plymouth voyager , blower works great but air will not deflect to defrost, stays on floor?
there is a actuator that makes a flap flow air out the defrost or the floor they work off vacuum . need to check see if vacuum hoses bad or broken .to get to actuator -the heater box under dash.
Nov 02, 2010 | 1997 Plymouth Voyager
Theres no tension behind the gas petal when i press it
The pedal is connected to a wire cable which runs to a valve or flap of some type at the intake end of the fuel injector under the hood. Either the cable has broken, or the spring which keeps the fuel injector opening closed down to idle position has broken or the cable has come off at one end or the other. Raise the hood and have a companion move the pedal up and down while you find the accelerator cable housing, most likely will be black. If the stiff wire cable inside the housing is moving with your friend's movement of the pedal then you should look to the end of the cable. You will see a small grooved wheel and the cable lies in that groove, and its movement turns the wheel which moves the flap inside. If the cable is not moving then your accelerator cable has broken or come loose at the pedal end.
Apr 28, 2010 | 2002 Toyota Camry Solara
I get air only thru the defroster, none onthe floor,
Usually a broken vacuum line will do this.The hvac system is designed to revert to defrost to keep the windows clear.Look for a broken or vacuum that might have come off.Hope this helps.
Dec 19, 2009 | 1998 Jeep Wrangler
Air condition vents on dash are not blowing any air, only the defrost vents on top of dash are blowing, any ideas
It sounds like the flap that controls air flow is stuck. It is controlled by vacuum. The vacuum line could be leaking, the line could be off, or the vacuum actuator could be faulty. Hope this helped.
Jul 17, 2009 | 2001 Jeep Cherokee
Jeep AC blows cold air at defrost and feet but not through vents
There is a flap that directs the air. the flap is controlled by a vacuum actuator. This is located inside the venting. The actuator is connected to little vacuum hoses that attach to the temperature control switch. Either the flap is stuck, or the actuator has gone bad.
Jul 01, 2009 | 1999 Jeep Grand Cherokee
The air selector for the heater/air conditioner moves but the air only comes out of the defroster. I need to know how to remove the console to see if the connector is broken. Can anyone help?
under the dashboard just above the gas pedal is the actuator rod to divert airflow from defrost to floor and vents. This may have come detached. move the wire/rod until it can be re-attached on the diverter door and wire-tie it on.
Apr 21, 2009 | 2005 Jeep Wrangler
Astro van 1997
There is a flap in your heater box that is controled by your vent switch by your heater controls. listen for a vacuum leak. that is common and hopfully the problem. there is vacuum lines that control the vent door that redirects the air to your vents.
Has your dash been messed with recently? if so i would check there first. you should hear a hissing if thats the problem.
Otherwise these also are common for that door flap to break and not switch NE more. thats the only 2 things that i can think of off th wtop of my head to be the problem. this would require the whole dash to come apart if its this problem
Michael
ASE certified
Feb 22, 2009 | 1999 Chevrolet Astro
2006 Wrangler AC problem
You have a broken vacuum line to the dash panel control.
Look under the hood on the pass. side next to the firewall.
You will see some vacuum lines, maybe one came off?
Oct 27, 2008 | 2006 Jeep Wrangler
Motorsports Logo
52 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
