Question about Wilton Grinders
Wilton bench grinder model 154
Trying to aquire a new 7" wire wheel
  • 2712 Answers
SOURCE: Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Posted on Aug 27, 2008
SOURCE: delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
Posted on Sep 11, 2008
rowdy45176
  • 2176 Answers
SOURCE: older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
Posted on Feb 01, 2009
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
I purchased a Wilton 6 in grinder, model 17203. It spins in a counter clockwise direction. Is this normal? In other words the wheel is turning down on the material being worked. Thanks Jim Price
Counter-clockwise as viewed from which end? The correct direction as viewed from the right end would be counter-clockwise. As viewed from the left end it would be clockwise. In other words, when using the grinder from the front, the surface of both wheels should be going down. If this is not the direction it turns, take it back. Good luck, Al K
Feb 02, 2011 | Wilton 17202 8" Bench Grinder
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
Cant get a on off switch anywhere co that maid it for wilton is out of business what a scam.
Repair parts have always been a problem.
See if you can get into the electrical area ... open the bench grinder from underneath ... tie the switch wires together ... put a regular wall switch on the electric line.
I hope it works for you.
Motor willnot spin blows breakers
well, with out seeing it I `d say you had a shot in the cord or switch. I hope this will help
Sep 16, 2010 | Wilton 17202 8" Bench Grinder
The motor just sits there and buzzes, when there isn't any electicity bearings turn freely
There is a short internally in the motor. IMO not worth repairing, new bench grinders are pretty inexpensive.
May 14, 2010 | Wilton 17202 8" Bench Grinder
WHERE CAN I GET TOOL REST FOR WILTON GRINDERS MODEL 170
Try Mcmaster.com (McMaster-Carr) page 2608, or enter Tool Rest or Grinder Pedestal in search engine.
Best regards, --W/D--
Aug 17, 2009 | Wilton Grinders
Older black & decker bench grinder
Jan 31, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Grinder starts and stops on startup
if this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Nov 25, 2008 | Wilton 17202 8" Bench Grinder
Grinders Logo
341 people viewed this question
Top Wilton Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Wilton Grinder Expert? Answer questions, earn points and help others
