Question about HP Office Equipment & Supplies
Cartridge Jam put 74 into 97 slot. now I cannot get 74 out of the slot>It is stuck
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Reset system and ease owt carefully, technician vey expensive for simple job
Posted on Nov 01, 2012
4 Suggested Answers
  • 990 Answers
SOURCE: I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
Posted on May 06, 2009
SOURCE: wrong cartridge in hp5610; can't remove it
this happened to me and this is how i solved it. take a pair of plyers and grab the cartridge from the sides and pull. it took a couple of tries and it came right out, intact and the printer resumed working properly.
Posted on Aug 04, 2009
  • 10406 Answers
SOURCE: I put the black cartridge #56 into the tricolor in an HP 5610 Off
It just is "jammed" into place, like a round peg into a square hole.
Use a bit more strength, in order to "unjam" it.
Or, if you are not comfortable, take it to a qualified printer technician,
and let him/her remove it.
Posted on Nov 19, 2009
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Per your user manual, here is a list of all the LED status':
Jam (b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
I was printing a report and had one page left to go and I noticed that it was out of paper. So I got some paper and put it in the paper slot. The printer fed about 6 sheets in a one time and that caused...
there is still paper stuck in the printer. open up the front of the printer (as if you were changing the ink cartridge) and remove the paper. Then turn the printer off and on. Good luck.
Feb 26, 2011 | Dell 924 All-in-One InkJet Printer
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
MY HP4 CARTRIDGE IS GETTING STUCK WHEN I WITHDRAW FOR A PAPER JAM. I FIND IT VERY HARD TO RESET THE CARTRIDGE AS IT GETS STUCK RATHER THAN SETTING IN PROPERLY; ONCE I SET IT IT AND START TO PRINT THE...
well u have to try to insert the cartridges in place before printing cause it may harm your printers health if not inserted properly what i will suggest is that you should watch some videos about how to insert the cartridge for your printer or you should read the manual carefully and if the problem still persist and your printer is in warranty call up the HP people and ask them to replace the printer.
Dec 31, 2010 | HP : HP4 Laserjet Printer
May 06, 2009 | HP LaserJet 1020 Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
15 people viewed this question
Seeker5211
Seeker5211
