Question about Sony Televison & Video
Service menu code for sony wega 32 inch for horizontal fix
  • SD Tech
    SD Tech Nov 02, 2012
    @ Gopakumar Gopalan if you know the entry code lets hear it---be aware in the tech menu someone doing the wrong things can get into serious trouble which you would of course know if even had a answer for this.
  • SD Tech
    To the asker of this question I ask you to reply here for more help and not be directed to another site.
    Top Expert:
  • Sony Master
  • 74,136 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 02, 2012
    Top Expert:
  • Sony Master
  • 14,553 Answers
It's done with the Sony remote---I hesitate to give that info as one wrong move and poof no set left.
What is the issue you are after?
SOURCE: sony fd trinitron wega 32 inch
Buy another TV.
Posted on Feb 17, 2008
joboo1
  • 257 Answers
SOURCE: Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Posted on Jan 28, 2009
  • 4234 Answers
SOURCE: I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Posted on Apr 07, 2009
rulds2008
  • 3866 Answers
SOURCE: Will not power up, stand by light flashes 9 times, then restarts flashing but never powers up
Well if you know eletronics then yes you could fix it yourself otherwise leave it to the experts you going to need a new power supply unti for this TV. These are not cheap as there aftermarket you may want to try to find a dealer on the internet for this part. Thanks
Posted on May 25, 2009
gerrywilson3
  • 10 Answers
SOURCE: The picture on my sony wega 32 has gone green,
sorry but the picture tube is shot, the power supply shorted about a 300.00 fix go buy a new tv
Posted on Jun 12, 2010
The horizontal and vertical picture is off. the last 3 inches of the picture is displayed on the top and it looks like double vision. can this be fixed without going into a store for repair?
hi,
You have a problem on vertical deflection. If you have basic knowledge in electronics you can fix it by replacing the electrolytic capacitors (100uf/50v,470uf/50v,47uf/50 )near vertical ic. sometimes these caps becomes leaky.
Nov 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture image does not look full when showing people
There is a service menu adjustment. I have seen several of these sets with bad components in the horizontal width control circuit. maybe your other set has a width problem. put both on the same channel. like cnn with the ticker on the bottom. what is the difference in size?
the width adj. procedure is: with the set off. use the remote, enter. MENU>5>VOL+>POWER . the set will come on in the service mode. then with the menu adj. buttons you can step threw the service menu to H.WIDTH adj. until full picture. also VERT. HEIGHT. when you are done adjusting make sure you press the mute button and watch the word WRITE flash from green to red or you won't save your adjustments.
Jan 07, 2010 | Sony FD Trinitron WEGA KD-27FS170 TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega 32 inch
Hi if light blinks on any sony tv it the fallowing
1 screen adjustment in expensive repair you need a tv center
2 power supply problem fix is 85.00 to 120.00
3 flybak problem high voltage est 225.00
this will at least help you so you will not be taken advantage of when you call a service center
thanks DOCTOR VIDEO LEADINGEDGEREPAIRCENTER SINCE1987
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Color lines/no picture
Well, if you still had a good picture before it happened, I would repair it.
This problem is usually a small part in the horizontal circuits. The service charges may be high, but the parts cost should be low.
This is a large heavy set, If you take it yourself to a shop you will save on the service call.
Jan 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
