Philips HDD SDE3273FC won't work on MacBook OS X
How can I install Philips HDD SDE3273FC on MacBook OS X? When I attach it, it shows up on the desktop but cannot be modified. It says read only. There is a folder on the disk called 'System Volume Information'. Inside is a file called 'MountPointManagerRemoteDatabase' which I cannot open.
  • Anonymous Jan 20, 2009
    When I plug mine in to OS X, the light on the ext HD comes on, but nothing comes up on the computer at all! INFURIATING>
    Problem Solver:
  • 20 Answers
Initialize drive, (remove old partition and create new for OS X file system).
Posted on Nov 22, 2009
MacBook Laptop Will not boot from CD and OS freezes during setup
Since you have an Intel Mac book you can boot to DOS 6.22 and use Fdisk to remove your partition at which point you can format it and install Mac OS.
Apr 12, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Windows error recovery
the 160 gb hard disk that you are trying to connect have the os installed earlier on the same system tell us
Jan 26, 2013 | Dell Dimension 3000 PC Desktop
Macbook won't start
ck the OS or may be ur battery discharged
Jul 25, 2012 | Apple Macbook Computers & Internet
I am a new macbook pro owner. My new mac will not recognize my external wd mybook which is several years old. What do I do?
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Jul 07, 2011 | Apple MACBOOK PRO WITH PARALLELS NOTEBOOK...
Hawking HWDN2 won't detect wifi networks when installed in a Macbook. However, it works fine on a WinXP PC.
That is because the macbook can't interface with it. Windows is a much more common OS than OS X, therefore most manufacturers focus on providing windows drivers. On top of that, Apple doesn't like to support things that it didn't make(and overcharge you for). So there is no driver for it on OS X, therefor the macbook has no way to communicate with it.
Jun 19, 2011 | Computers & Internet
When compuetr starts no boot device available but BIOS seen
If there is no HDD or any other boot device the BIOS will always be present. This problem occurs if you haven't installed any Operating System on the HDD. So when the computer is booting it finds no booting device files and that's why showing error message. Format your HDD and install OS to boot smoothly. But if you have HDD with OS still this error happening then it might be a reason of corrupt system files which are required during booting or it may be the case that your HDD is damaged and cannot boot from there. If your HDD is damaged and still showing on the BIOS it may happen because it is detecting as a device but the as the device is damaged is cannot boot from it. Check these steps to solve your issue.
Jun 21, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Blank screen with blinking folder
This is a sign that the startup disk can't be found.
When you power on the computer, try holding down the "alt" key or "option" key on your keyboard.
Then after a while, it should ask you to select the location of the operating system. Select your macintosh HD. Everything should load as normal.
If this doesn't work, insert the install cd's and hold down "c" instead. This will load the cd with mac os x on it. You can then install the operating system. Please make sure you have backups. Unless the option to simply upgrade or repair your mac pops up, you will loose your files following this method.
Nathan.
Apr 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Wont load
It is on your os problem. Insert your OS installer. You don't have to install a fresh copy but you can repair your previous OS installation. Make sure you have set your boot sequence to CD, floppy and last HDD. You can now reinstall your drivers after doing that.
Dec 21, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Mac notebook
IF you selected the BOOT CD option in the options are any other removable bootable media as a boot disk then it will not boot, otherwise your os hdd gone faulty then it will not boot
To resolve for wrong selection of boot disk press option button while u started your system that will show you the booting option there you must to select the OS HDD
Boopathy.T
Aug 06, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
