Question about Lifan Electrical Supplies
Governor linkage repair
Need picture of governor linkage on lifan 6.5 Hp
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
mickey813
  • 472 Answers
SOURCE: picture of governor linkage on briggs+straton
try this link all ya got to do is put in the modle #
Posted on Oct 01, 2009
bbreton
  • 437 Answers
SOURCE: location of governor linkage and throttle linkage
Try going to searspartsdirect.com. You can put in the engine number 143.955016 in the model search and it should give you a parts list and diagram for that engine.
Good Day.
Brian
Posted on Nov 06, 2009
Testimonial: "Thank you!"
rwvanlue
  • 486 Answers
SOURCE: looking for governor linkage set up took apart
cc4d3bd.jpg hmsk linkages
Posted on Nov 22, 2009
Testimonial: "Just what I needed. Thanks"
  • 100 Answers
SOURCE: i cannot find any decal that tells me the the
if its a briggs motor it is usually stamped in metal cowl either on front above sparkplug or side above muffler
Posted on Aug 14, 2010
I installed a 632690 carburetor on my older sears 10 hp riding mower. The mower starts but I can't adjust the speed. I need a diagram on how to connect the linkage
interesting
Tecumseh 632690 - Carburetor
if still original
the sear should have a Tecumseh 11 hp motor
the pictures are the original governor and carby set ups for a sears 10 hp
Oct 18, 2016 | Sears Garden
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
I have a craftsman tecumseh 4.5 hp mower throttle free type and i have cleaned and rebuilt the carb replaced the carb mounting gasket between the carb and intake and also replaced the o rings on the...
1ec7ba32-45ac-4b07-8389-f863014e42da.jpgIt still sounds like a carburation issue. Are you sure all jets, vents and ports in carb are open? Another possibility is that the governor setting is off. The governor is the rod that comes out of side of engine and connects to throttle linkage on carb. To set governor to factory setting, push governor linkage in direction that opens throttle valve, loosen screw on governor arm and turn rod in same direction until it stops, while holding in this position tighten screw on governor arm. This is called a static setting. If this doesn't work I would disassemble carb, remove all plastic and rubber parts and soak in carb dip overnight. Picture may be different from your unit but it shows governor linkage to carb. Good luck and happy wrenching!
Sep 18, 2013 | Garden
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Why would the engine idle at a very high rmp and the idle control seems to be function but has no effect on the rmp of the motor
check to see that there is no binding or issues where the governor linkage and the throttle linkage interact with each other at the carburetor. Check to see if any of the springs are missing also.It will be evident if so, linkage falling down.
Aug 17, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engine is surging after warmup on a BS 4 hp, no carb adjustment
This problem may SEEM carb related, but it is probably a result of bad linkage to the governor (controls engine speed) and may mean the governor needs adjusting (easy) or the linkage to the governor is stretched or not connected properly.
Aug 16, 2010 | Briggs & Stratton Garden
Location of governor linkage and throttle linkage
Good Day.
Brian
May 02, 2009 | Troy Bilt Walk Behind...
Electrical Supplies Logo
Top Lifan Electrical Supplies Experts
Steve
Gene Haynes
Are you a Lifan Electrical Supply Expert? Answer questions, earn points and help others
