Question about Sony Televison & Video
Wega 32 horizontal - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 74,459 Answers
What is the problem with your Sony TV? Your problem post haven't enough details to post a solution. Anyway, check this site and see whether it help you. If not, inform me by Fixya.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Posted on Nov 03, 2012
I have a Sony Trinitron KP-43T90, have sound but no picture it is a 2001.
Check its horizontal output section circuit for fault. Check the horizontal output transistor. If it found leaky, suspect horizontal output transformer.
Dec 21, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega kv-34hs420 worked fine last night never had a problem with it before. Today i went to turn it on and i get no picture and the stand by light is blinking 6 times every cycle
your tv has problem in the horizontal circuit caps in the horizontal circuit should be checked also the jungle ic.and the regulator in the power supply.have a tech repair your tv if your are not a tech. good luck.
Aug 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red light flashes six times
6 blink's means H stop or Horizontal Drive failure. Check the Jungle and its soldering connection terminals for possible bad soldering or loose connection. In some cases jungle ic found defective.also check your horizontal drive transformer windings and connection that is connected at the base of horizontal output transistor. Open winding or loose connection would result to absence of horizontal drive at the base of horizontal output transistor..
Feb 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Our 32" Sony Wega CRT TV randomly shuts off. It starts to dim then completely shuts off. This is happening at faster intervals. (Shorter on times)The indicator led blinks 6 times after the random shut...
    monitor if b+ voltage normal, if fluctuate check for the power supply area ckt parts for some discrepancy on biasing. if supply normal check on horizontal section area also replace crystal capacitor and check.
    Aug 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony fd trinitron wega Kv40
    The 6 blinks indicate a loss of horizontal and could ba a bad capacitor or bad jungle IC. I'll look up the part numbers anbd designations for you.
    Dan
    Jun 25, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony 32
    It more like the tuning capacitor(s) that is connected to the HOT that is defective or a cristalized/dry solder joint nearby the flyback transformer.
    May 30, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    I have the sony trintron wega 32 hs 500
    Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
    Bill
    Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony wega model KV-32FS12
    Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
    Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Televison & Video Logo
    15 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
