Question about AEG Refrigerators
Aeg santo fridge Frigorifico AEG SANTO 72348 KA 927718121
BIKER T
  • 909 Answers
SOURCE: AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Posted on Sep 20, 2007
SOURCE: AEG Santo 2340-8kg
I have the same problem - spent ages trying to find a solution and then eventually stumbled across this:
http://www.howtomendit.com/answers.php?id=16043
Haven't tried it yet but it's worth a shot. . . .
Posted on Jan 03, 2008
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
  • 1462 Answers
SOURCE: I have an electrolux Aeg
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Posted on Oct 08, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
I have an AEG Santo 72348 ka fridge that is supposed to be self defrosting. Mine regularly freezes up inside. Any help ?
Usually this is a symptom of a faulty door seal or a very frequently opened fridge they extra moisture load from the environmental air.
Feb 18, 2013 | AEG Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Feb 20, 2010 | AEG Santo 7085 KG Side by Side...
My aeg santo 70168 has a puddle of water at the bottom every few days.
if the water is inside check the drain on the back of the fridge if it is on the floor make sure the drain hose is in the drsin pan
Dec 07, 2009 | AEG Santo U 86000i Compact Refrigerator
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
Feb 24, 2008 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
65 people viewed this question
Top AEG Refrigerators Experts
ashburton
Ian Jones
David Jewell
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
