Question about GE Refrigerators
Off on panel kenmore elite - GE Refrigerators
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
We need to replace the lid switch on a Kenmore Elite Washer...how do you do that?
Look on the back side of your control panel.Remove the screws from that panel you will find documents about your Kenmore..
Sep 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
How do I find the Kenmore dryer model number, if I do not have the owner's manual?
There should be a sticker on the back and/or another on the inside of the back panel or on the door.
Kenmore Elite 23012 Washer and Kenmore Elite 63942 Dryer
Jan 25, 2010 | Kenmore 63942 Dryer
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
The bottom panel of the kenmore elite he4 wsher
There is a 1/4" screw on on both bottom corners. Take these two screws out and pull the cover from the bottom straight out. It hangs on the pedestal if you have one, so a little effort is required.
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite double oven control panel
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Dec 13, 2008 | Kitchen Ranges
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
