Question about Acer Aspire 5100 Notebook
Screen problems/overheating problems
Ok, I have an Acer 4520 Laptop. Vista OS. I have myself set up as Administrator and two other profiles set up. One one of them when we switch users the other profile comes up into only what I can describe as 3 mini split screens of the desktop. I can shut down from there but when I restart the screen remains black, I think the black screen is from an overheating problem.
I've done windows updates including drivers. Do I need to go to Acer's website and update all of my drivers from there or does someone else have a suggestion?
  • 1,218 Answers
Auto settings in NVIDIA control panel are those which control the temperature of the system.
It will check the fans revolution per minute and temperature. Actually it is always better to keep your system in an air-conditioned room which won't result in overheating.
By installing the case fans, it will divert heat out of your computer and increase the air-flow.
Get more information to fix Acer Laptop Overheating problem . Hope this information helps you.
Posted on Aug 08, 2011
    President:
  • 2,976 Answers
If it's an overheating problem, updates won't help, cooling will. With the unit turned off, blow out all vents & screens on the bottom, sides & back of the unit. Get a cooling unit to put under the laptop. Mine dropped the temperature about 30 degrees and it hasn't shut off since I started using it.
If it's not from overheating, the way you have Vista setup to view different users windows should be changed.
Posted on Jan 04, 2009
When i installed realtek high definition audio driver in my acer aspire 4520 os xp i found a modem device on high definition audio bus. the sound not working
Try downloading the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 23, 2011 | Acer Aspire 4520-5950 Laptop
I have installed windows XP on Acer Aspire 4520 and since it was not booting up normally i installed all the drivers in Safe Mode. Even after doing the same it's not starting normally just a blank (Black)...
your computer your laptop will just shut itself down and get a black screen unexpectedly, which is due to: power overload in the AC adapter, overheated processor / clogged fan, overheated battery, pushing the power button, Windows telling it to, the BIOS telling it to, loose wires (especially the power cord), or intermittent short circuits. The most common problem is cooling. the battery should be removed from the laptop and allowed to cool to room temperature before attempting to use again.
Oct 26, 2010 | Acer Aspire 4520-5141 Notebook
I have installed xp launch manager driver in my acer aspire 4520 laptop but it's not working
Did you install as Administrator, and RUN as Administrator too, also must have latest version of net framework
Mar 25, 2010 | Acer ASPIRE 4520-5141 AMD TK-57 1.9G 1GB...
Acer 4520 mystery
This generally is a software problem, install drivers and be sure to do a complete normal shutdown process
if it still doesn't find sound then make sure its enabled in the BIOS
Jan 01, 2010 | Acer Aspire 4520-5582 Notebook
No administrative priviledges on a Dell Vostro with Vista O.S.
try both versions of the OS (dual boot mode)
you logged in on the other OS
Sep 14, 2009 | Dell Vostro 200 PC Desktop
ACER 5630-6288 Win Vista Home Premium Admin Password forgotten
yes there is
login with ur normal user profile
go to run>>type cmd
in the black box...
type net user administrator
it will give u options to change the pwd for administrtaor
May 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Nvidia laptop sound drivers
Try downloading the appropriate driver from the Acer website. Note Acer shows your model of laptop having Nvidia Chipsets for Video and Motherboard, install the following drivers listed
nVidia Chipset Driver v13.11 Aspire 4520 Windows Vista RealTek Audio Driver v6.0.1.5413 Aspire 4520 Windows Vista
Here is a link to the main page - Click Here
Mar 19, 2009 | Acer Computers & Internet
Acer 4520 Web camara enable
I am using ACER (Aspire 4520), with Windows Vista BASIC & then once i have format my laptop & install Vista Ultimate on it from that time my webcam is not appearing on desktop & I am enable to use web cam & another problem is when I have install yahoo massager that was installed on the time I start working all of the sudden it disappear plz provide me solution of this
with regard
pawan sharma
Aug 20, 2008 | Acer Aspire 4520-5582 Notebook
Acer 4520 laptop
just format your drive by bootable windows disk and re-insatll the os.
Jul 05, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5100 Notebook Logo
297 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
