Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
Bose Speakers Won't Unmute
I've had these Bose speakers not that long and so far everything has been fine but today the "puck" I believe it's called won't turn on.The light won't turn green when I touch it,it just stays amber.
  • 4 Answers
SOURCE: Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Posted on Feb 13, 2008
SOURCE: Bose 901 and Tube amp
The tube main amp will work with series vi 901 equalizer and speaker but the main amp Valves will blow up easily as I have done
Posted on Jan 25, 2009
realmacoi
  • 18 Answers
SOURCE: no sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Posted on Apr 08, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
altec1105
  • 68 Answers
SOURCE: no sound through Bose acoustimass 15 series 11 on
Is a cord loose?
Posted on Nov 08, 2009
Turned my tv on today and only 1 speaker working (left front). Yesterday all speakers were working fine. Have unplugged everything and set up again but still just the one speaker working. Any ideas?
Swop left & right speakers, if only the right speaker works, the ex left speaker is faulty, if the left side still doesn't work, the problem is the tv
Aug 20, 2015 | Bose LifeStyle 50 System
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
Jun 11, 2017 | 1999 Chevrolet Blazer
Hello everyone. I need a cable for bose system CineMate GS. I want to connect speakers of another brand, but I need the configuration of serial cable to do it myself, someone can assist with the...
"CAUTION: Make no modifications to the system or accessories. Unauthorized alterations may compromise safety, regulatory compliance, and system performance."
That warning is not in the manual to just protect their market share. Even if you succeed in making the desired electrical connections the results may be less than stellar.
I'm not saying this IS the case but here is some Food for thought.
Bose's main claim to fame, the 901, was always based on achieving flat audio response from full-range speakers (NO WOOFERS or TWEETERS in the case of 901's) through the use of large amounts of prioprietary equalization applied to the audio signal. Another evolutionary step way in Bose amp/speaker systems was to deviate, sometimes drastically, from the 8-ohm speaker driver standard and design the mated amp to work with the selected load. THAT is just two reasons why no specs are published for the sub-parts of any BOSE SYSTEM. It's a system.
In the mix n match world of COMPONENTS specs are published so one can choose a given speaker for use with a given amp and expect electrical compatibility, frequency response and power handling.
Except for standalone passive speaker systems, mixing and matching Bose speakers with third party electronics (or vice versa) is discouraged as being potentially dangerous and at the least sonically unwise. For example, if you've ever heard how a Bose 901 Active Equalizer sounds with non-Bose 901 speakers you'd understand.
Maybe someone else can fill in the pin-outs of the cable and chime in on whether or not Brand X speakers will work with the Cinemate amps. Not knowing what other brand/model you're contemplating, it would be impossible for anyone to offer a qualified judment on that score.
Jul 12, 2011 | Bose Cinemate Digital Home Theater System...
How can i bypass the stock amp in a 2000 pontiac grand prix with the bose speaker system in it with out taking the bose speaker's out?
you can't. the bose system is just that, a system. you need all the pieces for it to work. the head unit doesn't have any power and you need the amp to drive the speakers. also, bose is a proprietary system. only bose parts will work for it. so you can't buy any amp off the shelf and swap it out. if the amp is bad you need to buy a replacement bose amp or replace everything with a new head unit and speakers.
Apr 12, 2011 | Car Audio & Video
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Bose companion 3
This is a common problem it seems with the electronics within the speaker set. (Companion 3 with sub and remote pod, aka, 'puck' = help desk support term)
I bought the multimedia speaker set in 2004 and had it replaced in 2005 because the 'puck' would not turn on (no orange light nor green light.) So I called help desk and they accepted the warranty exchange and I mailed the entire system (speakers and all) back to Bose in Markham, Ontario, Canada and they sent it back several weeks later. It worked 5-6 years after that as it is 2009 now, and it has the same problem again (no light on the puck). So I called help desk again and was ran through the same tests again (on/off, power plug off, various audio inputs, etc.) and the guy said to mail it in and they'd fix it as a non-warranty item. Cost: $85(Cdn) for repair + taxes, and $39 for remote pod.
So the sound that I got to enjoy from the Companion 3 system was amazing but electronic quality is very poor. For a set that cost above most other home user sets at FS and BB, it is substandard longevity.
I like Bose and have no complaints about the sound, but I will not buy another Bose multimedia package because at $350 (in 2004), I would expect it to outlast other sets. My friend bought a Logitech speaker set from another company in 2003 and is laughing at me as he realizes this is my second set and it hasn't even lasted as long as his own set.
Dec 03, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
145 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
