Question about MPC Computers ClientPro Computers & Internet
Switch vga to dvi in bios - ClientPro MPC Computers Computers & Internet
  • 2,878 Answers
I believe that option is on your monitor. Just connect and select input.
Posted on Nov 02, 2012
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
How to activate the VGA monitor port on motherboard Foxconn g33m02?
You need to use DVI to VGA convertor but mostly it is recommended to use a dvi compatible monitor. VGA wont work. Im pretty positive
Feb 01, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
Fpd1775w monitor no signal
Are you using the VGA cord or the DVI? If using the VGA switch to DVI, maybe there is a short with the VGA plug inside the monitor. a VGA to DVI adapter on the back of pc should do the trick unless your computer has a DVI connection as well..
Jan 02, 2013 | Gateway Computers & Internet
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
I have new intel dh55tc . I get display through nvidia graphics card . can I get display through vga.
Hi.
You can get a display through > DVI, VGA, HDMI which are on-board. You can also use the nVidia card which may be better.
Regards.
Jun 15, 2011 | Intel DH55TC Motherboard
My MAC G4 display has green and pink vertical streaks.
1. Try on another monitor to rule out VGA card.
// If overclocked return to default values, disable automatic overclocking if selected in BIOS, check cooling
2. Try another cable, if both VGA and DVI connections exist try switching between them ( cables )
Nov 20, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
