How can I turn on and use the heater model "ewt glen electric 90431"?
I don't have any instructions on how to use the particular heater and all my trials have failed to activate it. Could you please help me out and give me as many details about using it as possible, i.e. instruction or some advice at least? Thanks in advance :)
SOURCE: missing instruction manual
Bin It and get another
Posted on Jun 07, 2008
jsrock516
  • 5911 Answers
SOURCE: General Electric Washer
This problem is commonly caused by a pressure switch malfunction. This switch is located behind the water level or load size selector knob inside the operator console. If you remove the back of the console you will be able to access the switch. The pressure switch has some electrical connections and an air hose attached to it. The air hose runs from the switch to the bottom side of the wash tub. Air pressure from the tub increases as the tub fills with water and, depending on the water level selected, determines WHEN the water shuts off. Now...commonly what happens is the air hose comes loose from the pressure switch and it will no longer shut off. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
I would check the air hose, first. Often, all that is required is to reattach the hose and the problem is solved. However, if the air hose is intact and has no leaks or splits anywhere, I would recommend replacing the pressure switch. A replacment can be purchased online at searspartsdirect.com. Just type in your model number and look under the "Controls and Backsplash" heading for item number 10 (part #WH12X10065). Repairclinic.com also carries the same part for slightly less (item number 2205).
This is a simple repair (even if you have to replace the switch) and won't cost much. I hope this helps you. Let me know if you require additional assistance.
Posted on Nov 14, 2008
  • 10 Answers
SOURCE: assembling a simmons crib model no. 1320
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
customerservice@sjfdec.com
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, Cindy Customer Service Rep Simmons Juvenile Furniture ':Phone: 1-800-218-2741 ':Phone: 1-920-779-4004 7:Fax: 1-920-779-4216
Posted on Jun 01, 2009
  • 55 Answers
SOURCE: need instruction for voice-activated R2d2 toy robot by Hasbro fro
You can download the instructions from the Hasbro website:
http://www.hasbro.com/common/instruct/SW_R2-D2_Interactive_Droid.pdf
Blessings!
Posted on Jun 28, 2009
  • 55 Answers
SOURCE: im looking for the instructions of the walt disney
here are some suggestions http://www.gamefaqs.com/search/index.html?game=tarzan&platform=0&s=s
hope that helps you.
***Please Rate The Posts***
Posted on Jul 01, 2009
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Coleman heater 3500a820 lots of smoke and now only blower works no heat
I am not sure about the heater type, but likely the heater element controller shorted out or the heater elements shorted - hence the black around where the wires go into the electric box. If you're lucky, the wires shorted to the side of the box. With the power off, open up the electrical box, mark which wires go where, remove them from the board, remove the wires from the electric box, then using electrical tape, tape up the exposed ends of the wires. Spread them out so they do not touch each other. Turn on the 60 amp breaker - if it trips, then your wires are bad and need replaced. If it does not trip, then the problem is with the heater. Do not let anyone near the wires when testing them! Don't forget to turn off the breaker if it does not trip. Again, turn off the breaker if it did not trip.
Oct 18, 2012 | Coleman Heating & Cooling
We have a ceiling fan Apollo 52' Model 355-6788 but we don't have any instructions on how to put it up. Please send us instructions on how to do this.
On the remote part that goes inside the fan, it has five wire on it. One Red wire marked L goes to black switch wire from switch or Hot wire. Other Red wire goes to Net. wire from switch.or feed.Then you have A black, a blue & a white. They connect to wires from the fan. When finished connect turn light switch on, leave on & used remote control. Top left button controls the fan on/off. bottom left button controls light on/off.dimmer. There you go, all the know how to connect remote & fan/light up. Good Lucky.
P.S. You will need to buy a 9v battery for the remote, it doesn't come with it
Aug 13, 2011 | Heating & Cooling
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
On our AE125, the thermal cut-off is tripping AFTER the water is turned off. The heating element is getting so hot you cannot touch it
The elements are getting over heated then set temperature.You have a defective thermostat. The elements will continue to heat until they reach the set point of the thermostat. Try to lower the temp setting first. If that does not fix it, you'll need to repalce the thermostat, located very near the element, under the screwed cover on the side of the tank.------------- To know how this heater works, read as follows:---
Because electric tankless water heaters have to instantaneously raise the temperature of incoming water to a selected hot water temperature, they require very powerful heating elements. To power the heating elements of this 27,000 Watt model, you will need to upgrade the electrical service you were using for your storage tank water heater. The PowerStar AE125 will require a 240V, 200 Amp service. In addition you will need to install three 40 amp dedicated double pole breakers in your electrical box. In Canada, you will require one 120 Amp breaker.
The PowerStar AE125 electric tankless water heater incorporates a very sensitive flow sensor, and three heating elements. The heat from the electric elements is electronically modulated on the basis of the flow rate of the water entering the water heater, and the temperature rise that the water heater must achieve. Through its electronic modulation system, the AE125 maintains a very precise hot water temperature. As a safety precaution, each of the three heating modules is protected by an electro-mechanical thermal cut-out. This device will cut power to a particular module if the temperature gets too hot.
This will help.Thanks.Helpmech.
Jul 02, 2011 | Heating & Cooling
Just installed ignitor PP200 & Gma 10-R fuse, unit ran for approx 4 min & blew the fuse & burnt the ignitor up . Our parts available thru your location. Is their a troubleshooting guide...
It sounds as if you have a defective control board.
Find your exact model (example= B100T). Then, go to this page and find which board is in your particular model. Don't guess. http://www.reddyparts.com/master_heater_reference.htm
Then, go to the shopping cart for pricing & shipping cost.
Apr 20, 2011 | Master Heaters B155DST
Need to reignite the heater and the instructions on the panel are paritially destroyed. it is a minimax plus 250 and have tried finding the instructions on line
For an Owner's Manual for the MiniMax Plus heaters, which does contain start up proceedures for the electric and millivolt models, you can follow the link below.
http://www.inyopools.com/owners_manual/pentair_heater_minimax_plus.pdf
Make sure that you follow the directions for your particular model of heater.
Jul 05, 2009 | Pentair MINIMAX NT TSI IGNITER
Bathroom Heater
Check out this web page
www.glendimplex.com/brandstour1.php?id=23 - 20k
Perhaps they might be able to help
Hope this helps Loringh
Oct 19, 2008 | Heating & Cooling
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
